Just bought an r34gtt & have some spare parts from it that i dont need
Make an offer if you need anything
Can dropoff parts locally or post them,pickups from Mt.Gravatt Brisbane
Stock r34 gtt tail lights,no damage at all,no bulbs
I will sell them seperately
$150 ono
post-59075-0-78837300-1381399459_thumb.jpg post-59075-0-68278000-1381399470_thumb.jpg
Deep dish steering wheel & boss kit from r34gtt,Suede style material fairly new
Might also fit r32/r33/Silvias im not sure
$60 ono
post-59075-0-40918700-1381399496_thumb.jpg post-59075-0-46994200-1381399503_thumb.jpg
HKS[copy]Sequential atmo BOV with rb25det adapter,might fit rb20det's i'm not sure though
Cost $100 new,sell for $60
post-59075-0-41142200-1381399529_thumb.jpg post-59075-0-17737600-1381399542_thumb.jpg
Gearshifter fits skyline and silvias
$30 ono
I also have a stock black[Nismo?? spec] wing from bootlid up for grabs
I'll add a pic of it asap
Not sure on brand of steering wheel its was on car when I got it its almost new
Message sent to darksky34
I also have a plastic NEO rb25det engine cover in good condition
$40 ono
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
