Ronin 09- where did you get these and how much???
Looking for an exact set for BCNR33.
PM me with the details please....
JAG:
I've been looking at these also -
Advan $1500 in stock
Autobarn $1100 2 weeks
Jap Motosport $1000 2 weeks
all are approx price.
I'm very interested to see how they perform.
Regards
OK, I didn't really, I had to get someone to pick them up... what do you think?
They are Trust 3" primaries... :D
Hi Ronin;
I am seriously contemplating some of these myself. AFAIK there is no data available that compares stock, HKS, CES and Trust on an equal basis and although the Trust appear to be the best design it's difficult to know if their extra cost I justified. I'd would really appreciate it if you'd share your results after fitting them please.
Guest INASNT
JAG:
Regards
*** thats expensive for a pair of dump pipes.
The actual material, the price to laser cut the flange and the bit of mandrel bending needed is bugger all when u see that selling price
Hi Ronin;
Hey GTR32, get a set from Nengun with JAGR33 - maybe the shipping could be less...
The only issue that Gerald from Ice Performance can see (and I tend to agree to an extent) is that the primaries are very long, and hence a bit heavy to hang off the side of the turbo. But then, the bottom end of the primary dumps is supported by the Y pipe to the cat, so that isn't such an issue, methinks.
They are certainly the best design I have seen by far for stock / turbos that bolt on using the same dump system. The HKS seem (I can only tell from the pics i've seen online) to be not as well made.
INASNT, true, they are expensive, but they are hand welded in Japan - believe me the workmanship is incredible. It is all de-burred inside, the flanges have no welding slag etc., all in all an excellent piece of metal work. You are paying for the best.
As I said in my other thread, my mechanic and I are going to tackle it. Will let you know what happens (could be a few weeks though!)
Cheers
Guest INASNT
usually the small items like that are welded by machine and dont need to be cleaned up after coz it does it so perfect
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
