Hey guys used to do these all the time.
Meet and greet cruise.
Day time highway/ twistys run. Park up grab epic pub lunch and boost back
I was thinking heading south or west but im open to ideas.
Purpose is just to meet new people without the pressure of a dinner etc . And not as big as an annual number .
So who would be up for it I was thinking early late november
https://www.sau.com.au/forums/topic/433306-meet-and-greet-run-eoi/
So question is.......
South to broadbeach to bavarian beer cafe ( my favorite eatery)
or shorter
north to redcliff
as I said before I'm completely open to ideas
well broadbeach ain't too far from me and the Bavarian is well known for a good feed and BEER! :)
Need date and time and meeting point
bavarian is great but dont know if able to stop at 1 beer there and only one pretzel :whistling: !! what about parkin at bavarian? I mostly do public transport into city so not sure. Bavarian Beir cafe in brisy??
redcliffe suits me too im near the airport so either way.
Edited by smidy
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
