hey fellas, just bought a new r33 gtr has a hit on the front so ill need a new front bar & headlights.
Im really interested in buying a set of series 3 headlights for an r33 gtr & also if possible a series 3 front bar
any ideas where i can get them from any help would be appreciated
thanks jack :)
https://www.sau.com.au/forums/topic/433536-r33-gtr-series-3-headlights/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
