Hello all just wanted to check i wanted to purchase a Walbro e85 fuel pump part no F9000267 and also get a fitting kit 400-0085 as well to install into my Nissan skyline gtr 34.
Can any one confirm that it can be done what about piping and remote pick up with the sock as i know the gtr 34 has a fuel pump that sits high and has a remote hose that has a sock for intank fuel pick up from the base of the tank .
Will await to hear your answers.
thanks in advance
I did this 3 days ago, I had a Nismo pump in there already, I got the E85 pump with the rubber sock for the 255 pump cut the end off it and put it over the pump then hose clamped it to the factory location then took the fitting off the bottom of the Nismo pump and fitted it to the Walbro and refitted the factory hose to the fitting, then pushed the factory hose onto the top of the pump
I soldered the two wires into the factory ones about 100mm apart heat shrink then and zip tied so the two joints can't get close to each other
then I drilled a -6 bulkhead into the tank lid with hose fitting, attached the hose from the pump to that and ran the a hose from the top of that to the surge tank then two hoses from the surge tank back to the two factory tank ports
Many thanks for that,
So it fits ok no worries no problems, just need to find a way of not cutting the original Nissan fuel pump connector off, don't really want to as I might one day want to put the original back inside, so need some backward compatibility .
And under normal conditions the pump has the male end of the connector built into it .......
Any ideas on that part ?
From what I can tell the bottom of the pump from walbro has a foot sock attachement with a normal circlip crimp that pushes over the exposed stud, does this mean that the pipe comes with this sock/foot type attachment with a crimp style connector ?
I wouldn't be using the long hose remote pickup personally, as the pump will suck air through the fitting at anything under 1/2 tank. I would be trying to get the pump into the very bottom of the tank, into the cup in the bottom if there is one, and use the sock that comes in the box...
a bit concerned any one else done the conversion ? at this stage id be more inclined to go with a uprated nismo or tomei pump to feed the need for the e85 fuel as it seems more a likely replacement for the stock location and plugs but also because of the fuss of the bottom hose to sock connector ?
how about get a GT-t fuel pump cradle? I'm sure it will fit and now the fuel pump will sit at the bottom of the tank :)
It seems Walbros always need to be submerged, there are 2x little pin holes at the bottom of the pump.
I just picked up the same pump on the weekend, will be fitting it also (when I'm bothered) haha
why did Nissan have to go and make the gtr tank so different, I don't have a cradle for a GT-t and no access to one but let me know if this works and I will have to make a plan to get one .... tut tut any one else fitted one and managed to get a away with a install in the stock location with a long hose going into the tank with remote sock ? I presume the pin holes are there for lubrication etc ? and it being a intank pump will need to be submerged to work properly ..... what a pain
only just saw this, when I fitted mine the fuel light was on, fitted it the put direct power to it from battery and pumped out the last of the fuel, no probs, but I am running a 9 liter surge tank now and the walbro is just to feed it
the GT-T cradle would be a good idea but looking at it it doesn't look like it would fit so you would most likely need the whole tank
if the nismo is going to supply your fuel needs then that would be the way to go, just a tip the nismo pump is a factory TT supra pump :ermm:
the first Walbro turbine pumps have issues with the pin holes not being submerged but it was my understanding/i 'd been led to believe that this had been fixed with the new E85 ones
  • 4 months later...
so has anyone had success with setting up a new 450 l p/h walbro F9000267 in tank ? for e85 setup and is it really necessary to run a surge tank ?im looking at just over 400 kw
also what are you using for fuel rail setup ??
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
