Rb26dett engine from a r33 Gtr vspec, motor has done approximently 10,000kms since build. I have pictures of recent cold/dry compression test and can send or show to serious buyers only.
**Can fit and install for extra by mechanic locally on the Gold Coast pm for details**
Compression 160-165psi across the board
Bottom end
R33 Gtr crank
Genuine N1 block (24U)
20 Thou Cp pistons and rings
Eagle rods with arp rod bolts
Arp mains
Arp head studs
Greddy oil pump
N1 water pump
Tomei oil restrictor
ATI Harmonic balancer
Gates timing belt, tensioner and pulley all replaced in build.
Engine has been rebuilt, blueprinted, machined for 20 thou pistons and rotating assembly balanced. Block had been decked with all new welsh plugs.
Top end
Tomei Poncams 260deg 9.15 lift in and ex
Greddy cam gears
Timing Cover has been polished
1.2mm Tomei metal head gasket
Brand new rocker cover seals and half moon seals
Painted r34 Gtr red covers and plenum
Head has had a full recondition with all new retainers replaced on both sides, valve regrind and lifters serviced.
Engine comes complete with intake plenum, manifolds, all new hoses, r33 gtr sump, turbo oil/water lines, engine mounts, alternator and AC pulley and bracket. No injectors or rail or turbos, however can source parts and install on request.
Engine has been comprehensively inspected by a qualified mechanic, leak down tested, cooling system tested and compression tested, since removal. Has also been tested and run, is in perfect operating condition. Has been built for and used in a 300kw setup for drag purposes, perfect for track or street setup.
Price $8500
Located Gold Coast can Freight Anywhere Aus wide
PM or Call/Msg 0414596256
Edited by toy515
https://www.sau.com.au/forums/topic/433665-built-for-high-hp-rb26dett-for-sale/
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
