Antilag Racewars 2014 - 12Th & 13Th April, Wyalkatchem Airport
Antilag RaceWars 2014 dates have been released today, it will be held on the 12th and 13th of April once again at Wyalkatchem Airport.
Last year was ridiculously fun and I can't wait to wind some boost up, drop some kilos and better last years efforts.
Anyone else planning on going?
http://www.racewars.com.au/
More power is definitely required, seems I've got some quick cars chasing my title.
650 - 700 Sarah Jessica Parkers should do the trick I think ;)
will be entering
shooting for 650 - 700 whp for the event
hoping the 6 speed gives me a bit more pull in the top end
just booked my accommodation tonight, get on it lads isnt much close by around.
True that, I'm staying at the Dowerin Hotel ~20mins out of Wylie.
haha thats where i booked, ZZM5 has also booked at dowerin Hotel.
however am hunting down a house within close proximity of the track, so if we get house will just onsell the dowerin hotel rooms.
Hi, folks.
I enjoyed myself this year and have a point to prove next year! I have booked my accommodation in Dowerin just now. I hope it is not quite as hot and they iron out the kinks in the schedule. The organisers did a great effort for the first year.
Still learning to drive, it would appear!!!
:blink:
whats the point you wish to prove?
More to myself, than anything else. For lots of reasons, I stuffed up and ran in low boost all through the Saturday. Then on the Sunday I only managed two runs on the 1000 metres, because I was flying out that night and had to get back. The first one, the timing didn't work and I had a good indicated top speed. The second one, I stuffed the start and one gear change and the timing worked. So, I came away with the overall feeling that I had not driven the car to its potential. I want to do that this time.
So that is the point I want to prove to myself.
LOL I no own a 31 , 34 is just about finished :)
Weak :P
I only had the one run at 1,000m myself, I certainly had an average start and a short shift, could have gone faster but doubt I could have pulled up in time, haha!
Edited by Hank Scorpio
1000m = need good brakes.
Got to around 230-240 and felt "pretty" safe with hard braking.
Yeah, I think I'll need my 6-pots for if I ever get to 260-270 :P
  • 2 months later...
Entry is in! Looking forward to it - and hopefully not as much waiting around. But then, that is always going to be the case with an event like this. They do say that in motorsport, one of the phrases often used is "Hurry up and wait"!
Hope to see you guys there. :action-smiley-069:
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
