Wash, Clean, dregrease, clean, pull off brackets and bits galspray and then gloss black them...
If you start buying aftermarket gear to dress it up it will either look cheap, will be less reliable than the std stuff or you wont stop spending once the bug bites you...
Nothing is better than a ultra clean engine bay, you could look at taking parts off like the crossover pipe or top half of plenum even and getting them powder coated silver,
Dont use silicon sprays like armourall that will just make dust stick to parts, post a pic up and shows us what its like
Iv done mine amd I just unbolted amd took everything I could feom the sides of the bay and got degreaser with a rag and wemt crazy then get a good quality cutters amd cut and polish it then bolt everything back up
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
