Hi guys
Very time poor at the moment so please excuse the lack of detail/photos etc
Below is a list of items I can think of that are no longer longer needed
All to suit R32 GT-R, all BRAND NEW IN BOX:
1. Greddy hard intercooler pipe kit - $525
2. Greddy oil filter relo kit - $200
3. Mines RB cam gears - $200
4. Do Luck hard brake lines - $75
5. D1 spec carbon look bonnet latches - $50
6. Nismo braided clutch line - $85
7. TSC Extreme 4WD controller (same as in link below) - $190
http://www.ebay.com.au/itm/GTR-Torque-Split-Controller-TSC-GTS4-GTS-4-RB26-Stagea-SKYLINE-R32-R33-R34-/111196457368?pt=AU_Car_Parts_Accessories&hash=item19e3d34998&_uhb=1
All to suit R32 GT-R, USED PARTS:
1. Nismo lightweight flywheel - $250
2. Tein control master flex coilovers - $850
3. Mines Front pipe - $250
4. Mines dump pipes - $450 ($600 package price inc above front pipe)
All BRAND NEW to suit R32 GTR, NISSAN PARTS:
1. BM57 brake master cylinder (ABS type) - $400
2. Clutch MC booster - $200
3. Clutch master cylinder - $165 ($350 package price inc above item)
4. Have other items inc ball joints, steering rack boots, thermostat + housing, etc
All prices are + postage
Txt/call me on 0407 175 417 and I will send you through photos asap
Cheers
Couple of items sold
Few more on hold awaiting payment/pickup
Cheers
http://www.ebay.com....e3d34998&_uhb=1
Items below are now sold
4. Have other items inc ball joints, steering rack boots, thermostat + housing, N1 washer bottle etc
BM57 brake master cylinder (ABS type) =
A MUST if you have upgraded to 33/34 GT-R Brembo's and/or larger brake caliper kits (AP Racing, D2, Endless, Project Mu)
Teins SOLD
Quick photos of few things below:
Nismo flywheel machined and ready to go
Bonnet latches (will suit any car)
4wd controller
  • 4 weeks later...
  • 4 weeks later...
Hey mate,
Interested in the torque control, bonnet latches and nismo clutch line.
Could you PM a package deal with postage to WA 6019
I would like it express posted to. :)
PM sent too.
Michael
Edited by intercpt
  • 3 weeks later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
