Good evening all,
I was bored last night and during my channel surfing I come across tapout xt on the infomercial channel. It seems to be a cardio/ resistance type workout and was just curious if anyone has tried it. I also found some info on the rushfit workout as well so I thought I would mention it. I am a bit hesitant with everyone watching me at the gym while I die attempting some of there cardio workouts and thought maybe it would help enough to start out on. ( especially when I can get both cheap as ) Any thoughts would be greatly appreciated. Thanks All
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/
I have been going to the gym for about 8 months and trying to build muscle however I am short and stocky and i want to get more definition. Basically I wanna drop fat and build muscle which I am having trouble doing. I am seriously thinking about giving this a go to drop the body fat than go back to the gym
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081284
I understand that rev. When I first started going to the gym my heart rate was 160 at about 6.5 km/ph on the runner. In the time at the gym I can now run 2 kms in under ten minutes as a warm up before I hit the weights. I have also stopped eating pretty much simple carbs as my diet pretty much consists of oats in the morning with a protein shake than chicken and brown rice for smoko lunch and pre gym snack ( sometimes with semi dried tomatoes and feta ) than after workout I will have a protein shake and than dinner which usually consists of sweet potato chicken/steak/kangaroo and lots of veges . Only on leg day will I have some potato after a workout as I usually am very wobbly afterwoulds with tea. I usually have one coffee in the morning with one sugar and occasionally a can of Pepsi max during the day.
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081449
Ok that sounds like it's healthy and all good changes for the long term. You body composition will gradually change to reflect what you are now doing.
In terms of matching your requirements , it's about how much. So how much rice and how much chicken vs your requirements.
Plenty of people do similar to yourself and find changes are small and slow. If you are eating relatively large portions or too small it stalls progress.
Have you done a basic portion vs marco check?
How lean do you want to be and when are you wanting that to happen by?
Building muscle AND dropping significant fat is a challenge:
a) Because it's suibjective
b) Because the rates and potential are genetic (also see above)
c) Because packing on lots of muscle at the same time as dropping body fat is much harder than doing just one of them. Requires more commitment.
Rush Fit and Tapout infomercials feature the usual people who built muscle in the gym then did it for cardio. The lean bit they got from the kitchen.
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081550
I have had a look at iifym and derived a sort of basis. I have a bowl of oats for breakie than breakup half a chicken to be divided into 3 meals and same as for a packet of brown rice ( I think 250mg divided into 3 ). I use the microwaveable packs as they just so convienent and than for tea I usually try have a good size of protein ( 250-350 gram steak or chicken etc) I am currently sitting 78 kilos and am 170 cm tall. I usually go to the gym 3-4 times a week. Ultimately I would like to grow some size but lower my body fat
Edited by Kenna802
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081697
To be honest rev I don't really have an answer. All I know is when I look in the mirror I'm not happy . All I do know is I want to get abs I can see ( I have about an inch of fat hiding over my lower abs and about half an inch of fat over my middle ones as well as increase my puny arms and generally increase muscle all over. I know I have made gains in the 8 months I have been doing this as I have built up to 3 sets of 80 kilos at 6 reps each. When I first started I couldn't do that at 60kg
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7083587
You need to 'quantify' those goals. Numbers. Size measurements . You can go with waist measurement for example. Be realistic.
Seeing abs is one thing , however , if you have never seen them before your expectations are based on unknown. This leads to dissapointment.
Takes time to get lean, takes time to get fat. Be realistic but, commit to things that can be measured. The subjective puts you in danger of image issues even when you have achieved alot.
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7084809
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
