If you want a gain there are two things I would do as a first step:
1. Replace the the stock upper link mounting bracket with either a Nismo item or a stock item remanufactured to be like the Nismo geometry or run one of those top links with the bearing in the middle of it (which I dont much like but each to their own)
Is this the one (kit with mounting bracket, lower control arm and radius rod)? http://www.nismo.co.jp/en/products/competition/lb/skylinebnr32.html
I guess the lower control arm must be different. I already have the nismo radius rods and i believe the only difference is the wider bush.
What would you go for? 6kg/ 7kg?
Its 'moot' not 'mute' :) Also - I would have thought that the type of tyres could not effect under/oversteer balance - am i wrong?
Well you are running 450/350 lb/in. I assume they are 2.5 spring ID's and to be honest I would buy both and try both a 400lb and a 350lb spring. It is one of those things if you try the harder of the two and the car likes it you go another step. You can also go up/down in 25lb (.5kg/mm) increments although the general rule is 10% otherwise you are wasting your time unless very close anyway. Springs are cheap tuning devices which probably explains why I have boxes of the things laying about home and no, none in that range, sorry.
Give Troy a break he was probablly on an ipos of some description with an autocomplete/correct.
The type of tyre does have an effect. Some like more camber than others, for example due to their sidewall stiffness or may be more sensitive to it due to their construction. See the photo for the difference between an A050 & an RE55. Which do you reckon is more sensitive to camber?
Yeah but they are drug money given they are just stock components drilled or bushed differently and painted silver.
The castor rod is 5mm or so shorter with a harder than stock bush
The LCA has the outer mount 5mm or so further out. Is same casting.
The bracket has different drill points. See the attached drawing. Pretty common for production style racers to weld/redrill and generally butcher these things. May be an option - I think Fatz did it to his 32.
This ..3 deg is a fair bit of camber if you call KU36, Federal 595 RSR and Advan AD08 semis (a lot of people do these days) if you are running RE55s and the spring rate and roll package you are... I would guess its about close to optimum. With AO50s it could very well be not enough.
I ask because the rule is softer springs and less camber is generally required with grippy street tyres. With premium street tyres , running too much camber means you never generate the grip to generate the roll to use the face of the tyre and you end up with an understeery car.
My car was finally sorted on RE55s then I moved on to AO50s and have had to change a few things re springs, alignment etc to get it how I want to drive...and its still not there. The thing is way quicker on AO50s but I still have not got the balance of the car as sorted on the AO50s.
So from my experience above is why I asked about tyres. And going back to when I ran street Falkens one track day with my optimised RE55 setup,...was a washy piece of understeering poo that was hard to get in, through or out of a corner
This. In spades.
There is a trade off between suspension geometry, spring and anti roll bar rates. Put simply your geometry will give you camber compensation in roll (because it has wishbones rather than MacPherson struts). How much depends on arm lengths top and bottom.
The higher your spring rate and anti roll bar rate the less the car will roll (obviously) and the less the camber compensation in roll will come into effect. The more grip you have the more roll you will get. You need to balance all of those things to achieve what the tyre wants. If it is a S spec tyre (I think that is what they are calling them) like an AD08 it will be in the middle of a road tyre and an R compound in terms of camber requirement.
I suspect that the reason Japanese track biased suspension is so hard is not because of the smooth circuits nor because they dont understand roll bars but more that there is no easy way of sorting the front suspension on an R32 to get the camber right and have it liveable on the road on road tyres.
Be interested to hear Troys thoughts on the RE55 vs A050 differences. My impression is that the Yokies are:
Less one dimensional in term of grip ie they will turn and brake/accelerate more happily than the Bridgestone.
Less sensitive to suspension changes than the Bridgestones - mostly due to the crown on the treadface.
Quicker by atleast half a second a minute.
Need much lower pressures.
I'm running R888s, but will go for a new rim/tyre combo when they're done because i want to use the 34GTR rims for street.
Well the common view of R888's on GTR's is that they suck the balls of a dog on account of there being insufficient sidewall stiffness for the weight of the vehicle.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
