Hi all,
cant find from searching,
will a Nistuned ecu from a manual R34gtt adapt into a C34 RS4-S stag?
appart from obviously needing to be retuned is there anything different which would stop this from working?
would i need to separate the board or could i swap over the ecu itself?
thanks for any help.
glyn.
https://www.sau.com.au/forums/topic/434143-r34gtt-nistune-rs4s/
You should be ok as all the maps and settings you can see are the same however the issue of traction control and what Nistune does with it might cause some background issues.
The board can have the correct base image loaded onto it by Nistune or some of the dealers with desoldering gear but that will cost around $50-75 depending on how they are feeling.
i know its a different product but a link g4 sells for an R34gtt and they plug straight into a C34 RS4-S (they market this fact aswell)
so i reckon a nistune in this instance might work.
however these are marketed for the series 2 rb25det NEO engine wont work with pre neo engine
Talking to my tuner about this months ago. Nistune will work in a s1 if you convert to manual. You can use the neo ecu on a s1 & s2 rb25.
I haven't been game to try the auto r34 ecu in my auto s1. I read some threads from years ago where the car would start and drive but would eventually die
It will work BUT if you use the wrong base image you are never sure what the factory ecu is doing behind the scenes. So in the case of running an R34 GT-t image you will throw a trouble code due to the lack of traction control. You can switch the notification off but it may be doing something in the background.
My RS4S was a pain in the arse on throttle recovery. It took me a long time figure (it went past 2 tuners as well) to notice that the base image was an auto image. I had the board re-imaged and I wish this had been done 2 years earlier...if it had been done right in the first place it would have made the car nicer to drive day to day in traffic.
well im looking at a bord from a MANUAL R34 GTT NEO into a MANUAL SII Stgagea rs4s NEO
the compatibility should be fine but i dont know if theire is other things on the ecu cuch as the 4wd which may get disturbed.
Again
4WD is not an issue AFAIK, more a case of whether the ECU is correcting the commanded values to protect itself.
The commanded values within Nistune for an R34 GT-t/RS4/RS4S look identical but some tables are not visible within Nistune so it isn't always easy to know if the output from the ecu isn't altered.
Keep in mind Nistune is a work in progress.
Edited by wolverine
It will be fine if you load up the right base image on the board whichever ECU.
It will probably be 99% fine as is...but it might give you a few niggling issues that $50 re-image will fix. Ask the guys at Nistune they are generally very helpful.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
