Selling some R32 GTR (RB26DETT) gear off. and a couple of 34 bits as I need cash
New Harmonic Balancer - ATI (Super Damper), - 500HP - $400
  • Eliminates torsional crankshaft vibrations
  • Exceeds SFI 18.1 specs
  • Black zinc chromate finished
  • Tunable, rebuildable, and extremely efficient at ALL RPM
  • Laser engraved 360° timing marks
New OEM Injector Ballast Resistor - $100
New Dspeed smoked indicators - $300
Near New BM57 (ABS) - $300 (couple of hundred KM's)
New SRI Front Upper adjustable control arms - $175
New SRI Cold Air Box Kit for R34 GTT - $140
^good savings^
Used parts in good working order and condition
Denso 720 Injectors - $350
Nismo Oil cap in Packaging - $75 (Brass/Rose in colour)
Steering Rack - $100
Power Steering pump - $100
Starter motor - $100
Front Bar Mesh - $50
Front Seat belts vgc - $150
Cusco Strut Brace (round) - $50
5Zigen JASMA exhaust muffler - oval (axle back) $175. As new.
Professional Custom made Exhaust true 3" cat back with Mid muffler & Oval tail muffler (mandrel bends etc..) under 1000kms no damage - $450
HID's for N1 headlights with globes & ballasts - $100. Fitted and used for a few weeks.
Pencil Shift light (forget named brand will check) - $50
Considering parting with:
- NISMO Blank Keys in packaging - 1 x 8 point, 1 x 10 point. Open to exceptional offers (via PM only).
- New Genuine N1 front bar with OEM Lip and N1 Vents in Original OEM Packaging - $900 (as a package only)
All + Postage.
PM me and I will get back to you.
(more parts may be added so check back)
R34 SRI CAB - Sold pending payment and Pick up
OEM Mesh - Sold pending payment and Pick up
All PM's responded to re Nismo Keys, thanks fellas to low - Still 4 sale.
Pics of Indicators and oil cap as requested.
I'll take a raincheck on that Terry thanks for the offer though, I'll be off to Japan in a few weeks so might just save my shopping for then! Enjoy your new one!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
