After recently breaking my motor I have decided to part it out.
Here are some parts to start with,
Hks T51R KAI BB turbo setup - $6000 Ono.
Includes:
HKS GT II 60mm wastegate with stainless screamer
HKS turbo manifold
Stainless Dump pipe heat wrapped
Stainless braided oil and water lines with AN fittings
Custom stainless 4" intake with k&n pods
Haltech Platinum Pro ECU - $1500
Teflon braided fuel system - $1000
SARD surge take with 2x 340lph internal fuel pumps
1x Walbro lift pump for fuel tank
2x -6 Teflon stainless braided lines to dual entry fuel rail
Tomei dual entry fuel rail with AN fittings
And relays
Splitfire coils 6mths old - $450
Zeitronix O2 wide band AFR sensor kit - $200
HKS type R front mount intercooler - $300
Ati balancer - $400
PAR dog engagement 5 speed gearbox with larger Hollinger input shaft - $5000
$5500 with triple plate Orgura clutch
Profec B Spec II boost controller -$250
Front Nashin 6 piston, 355mm front brakes forged calipers with braided lines - $1600
Rear Brembo R33 GTR calipers with SRT pads - $250
KAAZ front and rear LSD diff's - $900
Tomei 320km cluster - $200
Mines 3 center cluster upgrade - $150
AEM EGT exhaust temp gauge - $70
AEM oil pressure gauge - $70
4x rear spare drive shafts complete - $150 per/pair
Alloy racing radiator with twin Davies Craig thermos - $250
Nismo water header tank with lines - $50
Nismo strut tower brace - $100
HPI engine damper original - $100
Earls oil cooler with oil relocator and braided lines - $100
18x10" x 4 rim's with worn rubber
Body parts and interior also available
JUN 264 9.7mm lift IN/EX cams - $300
2x Gates Racing adjustable cam gears - $200
Any questions PM or SMS on 0414918758
https://www.sau.com.au/forums/topic/434303-parting-out-my-602kw-r32-gtr/
Just letting everyone know,all the parts were functioning just the way they should of, this selling of parts wasn't planned. The engine broke due to over powering my rods which didn't support 600kw I found out the hard way.
All bearings in the engine are ok except the small end on cyl 6
  • Like 1
Thanks for the crazy response guys.
I've had so many messages and sms's I haven't kept up but tomorrow I will be checking the times of each message and the parts you are requesting and giving the opportunity to the earliest received message to be fair.
I will also be taking pics of parts you have requested as well and replying via SMS or pm directly with the buyers.
Thanks again guys, I want to be fair to everyone so don't stress.
Im sad your parting this out. Just rebuild the he motor. I want more youtube clips lol.
Edited by Joshbigt62r
  • Like 1
Sorry to hear I miss fortune man ... Just out of curiosity what make were the rods that broke , build a big hp rb26/30 and the moment and just wondering which rods you are referring to , pm me if you don't want to post that one thus thread ? Cheers mick
They were Trust h-beam rods that were over 16yrs old
Thanks Josh, maybe ill do a crazy 34 in the future but not right now, family priorities... I will try to continue uploading crazy footage on YouTube with friend's RB's and builds
Currently everything on the list except the following are sold
And still available
- HKS T51 setup still available
- Dogbox with triple plate clutch
- Gates adjustable cam gears x2
- 1 pair of drive shafts
- Splitfire coils
- 5Zigen steering wheel and boss
- Blitz torque controller
- some body parts and interior parts still available, just ask
Prices are listed above and are negotiable.
Thanks to everyone that has bought and paid so quickly, the parts are already started to ship
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
