S A U - N S W Summer 2013 Tech Night For Members 6Th Dec At C C S
Hi Terry/Execs.
Could you put me down on the next update, previous plans have fallen through, so I'm free to attend! Yay!
Bring Jenson for the next stage of indoctrination?
would it be beneficial to do a window tinting session to show how its applied and whatnot?
Ive been meaning to get my door windows done for years
Hi
I did ask if Daniel wanted demo cars but (and there's that word "but") he already has his props Dave.
Cheers
Still awaiting my membership....its been 3 months at least lol
Being asian like me, you didn't try and cut-price with Shell did you? Shell hates hagglers. She expects people to pay full price for her services. :P
Anyway, you're IN
Terry I still haven't received my membership card since I applied in September, do I have to show it to get into the workshop???
You didn't suggest to Shell that she might be breeding a Treasurer did you? Shell hates Treasurers. :P
Hi Terry/Execs.
Couldn't you think of a better excuse than something so passe Alex?
Acceptable is...
* We're having a break from trying for #2
* I feel deflated after missing out on a decent Forester XT to replace my Stag
* I'm addicted to Tech Nights and I couldn't pull myself away, so I gave in
You're IN
Lol! I didn't bother her about it - just paid the money asked her how it works :)
I'm keen Terry, any chance you can squeeze me in?
Pending Membership Approval Daniel, SURE!
http://www.hgeconsulting.com.au/membershipform.pdf
gah! is there still time to become a member? My misses and i wouldn't mind both signing up and coming to this event.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
