Hi Everyone,
I'm relocating from SA to Springfield Lakes. Can you help me with a suggestion of where I should go for a RWC and mod plate?
In another thread I was told my car looked low and that the cops would pull me up straight away. I believe my car is standard height and it's the illusion of the kit that give it the appearance of being low.
Here are the photos I took for the transport company
I can get 2 fingers in between the tires and guard front and rear. Is it too low?
Any help would be appreciated.
Cheers.
space between guards and tyres is not an issue, as long as the lowest point of your car (including the exhaust just near the diff) is above 100mm
What parts of the car need to be mod plated?
Everything is above 100mm (when checked on level ground)
I have no idea what needs mod plating (because I'm not familiar with your regulations)
My list of mod are:
Secured Apexi pod (not in a box)
z32 AFM
hard suction kit
T04 Turbo
Stainless ext. manifold
Turbo back ext. with hi flow cat etc. Not loud
Manual boost controller (22psi)
FMIC (metal was cut to accommodate the piping to the throttle body)
After market BOV that is 100% recirculating
Q45 Throttle body
Freddy forward facing intake manifold
1000cc injectors
Top feed fuel rail
Turbo smart FPR
Walbro pump
RB20DET ECU with nistune, running E85
permanent wideband lambda, boost, temp gauges to DLP-I08 and Consult
I think that's about it
You will need a mod plate for the turbo at the very least and the hole for the FMIC will probably need to be certed as well, as for the rest I'm not sure. The reo being cut will be a defect if it is found and can't be mod plated.
I know of a mobile mod plate guy on the northside but I'm not sure how far he roams to plate cars. As everyone said keep your SA rego until you have everything up to scratch.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
