After months and months of research, I've decided to go the OS88. Went for a drive in one and it was awesome. Quiet in gear, bit of clunking between gears but who cares about that, 4 choices of ratios and 6 speed. It also bolts straight into a R33 GTR so no shaft/transfer case changes.
It won't happen this year, but it'll happen. :)
We ended up with a Quaife/Trust 6 speed straight cut dog box, will be interesting to see how long it holds up.
My money is on the input shaft going first.....
GTRPSI: Be careful with the reverse gear on the Trust. It's only 18mm wide and the idler gear is smaller still. They have a tendency to not want to engage properly and the idler teeth are easily ground off if not engaged fully.
What shifter are you using on the Trust? How much power do you have?
Top choice, Piggaz. I'm in the same boat with the OS88 - it will happen eventually.
Straight cut is never an option. UNLESS, there is the top gear is helical. Freeway driving is important to a few guys in this thread.
How noisy is it. Can you take some videos?
New reverse gear has been fitted (guess why), and its a H pattern.
PT7175 on a 26/30 with E85, what power i plan to get and what i really get may be 2 different things, so no results to speak of yet as engine bottom end is going through assembly right now.
Just got it minus the transfer case, im going to rearrange the plates in our old transfer case (transfer case mod) and bolt it on, its been rebuilt, sitting near me right now waiting for the new engine to be finished.....
Spent yesterday gaping the rings, bottom end should be assembled next weekend when i find some time.
Not intended as a daily, more a 1/4 mile and Saturday night special, just put some ear plugs in if too loud. :)
Edited by GTRPSI
I was leaning towards a PPG straight cut dog box.. thoughts on that one?
A lot of people use them with what seems great success. That second gear is almighty tall though.
The BC Automotive GTR was using one.
GTRPSI, I would suggest you get a gear shift lever made up as the stock bush type one doesn't help reverse (the main reason they get damaged).
Can you elaborate on the getting a gear shift lever made up?
I was unaware of that issue....
Thank your your wise words.
Will hunt for the clip later tonight. :)
  • 1 month later...
What are the options as far as straight cut dog boxes go?
I found a PAR dogbox for sale on ebay that was going pretty cheap, but apparently PAR's boxes are shit.
I hear Quaife/Trust are pretty good, but parts are hard to source.
And of course PPG, which are good but pricey.
Any other options out there?
I went out and spoke to Terry at Award A few months ago. He said there are two new options for us. Both are dog boxes and 6 speed I believe. That's all the info I have. It might be worth while giving him a call as he said he will have more info soon.
Apart from those two and what you have mentioned, I haven't found anything that stands out.
Found this on eBay, is that what they are worth?
http://www.ebay.com.au/itm/Nissan-R33-Gtr-Rb26-PPG-5-Speed-Straight-Cut-Dog-Box-/321456969727?pt=AU_Car_Parts_Accessories&hash=item4ad85417ff&_uhb=1
I am not putting out astronomical power (under 300kw) so other than advantage of quicker shifts I am having trouble seeing the value in spending over $8k on my gearbox. Yet, I still want one :ph34r:
I contacted Quafie and they put me onto the people who they made the boxes for, all parts are still avaliable, they also told me each part internally has a part number stamped on it, you just contact them with the part number, so to make it clear everything is still avaliable for the boxes and they also made it clear that they will continue to support parts for them.
Quaife Engineering made the boxes for Trust Japan originally. And yes, they have plenty of stock for all major parts.
Piggaz, Holinger and the OS88?
A copy of the email from the people who Quafie directed me for parts....i was chasing a bigger input shaft for ours for drag racing.
Hi Peter
I'm not sure I have much to tell you in a positive way, sorry !
We made that kit between 1992 and 2001, there were many changes made to it over the years, Here is a short answer to your questions ;
1. yes, we can still supply all the parts. The easiest way to quote, is to give me the part no. from the old item. Most of them start E3F1 and then two or three more digits, Numbers are stamped onto nearly everything apart from small parts and bearings
2. Bear in mind this kit fits into the stock casing This means gears are stock diameter. It also means ultimate power handling is restricted Probably to about 750 hp at the flywheel. We have a much newer much stronger sequential 6 speed far more capable of power in the 1000hp area. In my opinion, unless you have less than 750hp and dont mind a potential waiting time for spare parts then you are wasting your time with this kit. It was made so as to achieve 300kmph in time trials in Japan, not as a drag race or high strength kit. Anybody claiming to handle more than that power through stock diameter gears is talking BS. There is at least one manufacturer out your way claiming that !!
Hope I can help you further
kind regards
Website...
Though i might share some info from the horses mouth about the 6 speed H pattern Quaife/Trust Dog boxes. :)
Part of the reason I am looking at a dogbox is they are supposedly 'stronger' than a regular gearbox as they can take more power etc. but the more I hear about them the more temperamental they sound and it seems like the running costs don't get any less after the initial outlay.
After buying a dogbox, what sort of dollars are required to maintain it once it's in? Does it matter that I'm not running a lot of power?
I have used a ppg dogbox in a commodore cup around Wakefield and it was awesome, so I know the benefits when driving with one. It's just for $8k I could buy 8-9 regular gearboxes :P
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
