Nah man. Was ordered two months ago. I'm betting late February if delivery in Japan works well with the container it's being put in.
They both have taller ratios.
Assuming a 265/35x18 tyre and stock ratios and a rev limit of 8000 RPM the speeds are as follow
Stock
1st - 75
2nd - 120
3rd - 180
PPG Helical and straight cut dog
1st - 89
2nd - 143
3rd - 189
OS GIKEN
1st - 87
2nd - 138
3rd - 190
Is the os giken speeds that you have showed are they the correct speeds even with the close ratio gear set? I would have thought that the closer gear set would shorten at least gears 2,3,4 and 5? Ow btw are those figures for a 34 ? Or 32 gtr?
Edited by boobeedoobee
The OS GIKEN 5 speed is most definately taller than factory gearing. That is assuming 4.11's in the diffs. Gts4 ratios will shorten that by 7% iirc.
What's the setup?
It would make the gearing awfully short with the 4.11's. You'd be changing gears like an Evo. It isn't the cheapest conversion to do.
Like he said what's the set up?
Set up is an r34 gtr getrag 6spd gearbox fitted to a 32 gtr .. it's the whole box including everything needed to do the conversation
By setup I meant what's the engine/turbo combination.
Boobee. The reason I was asking turbo/engine combo is that (and this is my opinion only) the taller gears in the OS set make a lethargic bottom end of a 2.6 L engine and make it even more pronounced.
For example, a mate on here on a pretty decent R33 GTR put one in and ended pulling it out and going back to stock ratios. That was predominately a track car too. 2.6 with -9's and -5's at different points.
Just something to think about.
Bakemono. Cheers man :D. Be good to drive it again lol.
Oh the lols
only do the Getrag if you do the 3.545 diffs as well, 1st gear in my 34 is now and always was useless even when it was a 2.6 with -7s, so add 4.11s to that and you may as well stay with the 5 speed as you won't use first with the Getrag
I can't wait to see the difference between 4.11s and 3.545s with the two identical OS88s once put side by side :D
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
