Nah man. Was ordered two months ago. I'm betting late February if delivery in Japan works well with the container it's being put in.
They both have taller ratios.
Assuming a 265/35x18 tyre and stock ratios and a rev limit of 8000 RPM the speeds are as follow
Stock
1st - 75
2nd - 120
3rd - 180
PPG Helical and straight cut dog
1st - 89
2nd - 143
3rd - 189
OS GIKEN
1st - 87
2nd - 138
3rd - 190
Is the os giken speeds that you have showed are they the correct speeds even with the close ratio gear set? I would have thought that the closer gear set would shorten at least gears 2,3,4 and 5? Ow btw are those figures for a 34 ? Or 32 gtr?
Edited by boobeedoobee
The OS GIKEN 5 speed is most definately taller than factory gearing. That is assuming 4.11's in the diffs. Gts4 ratios will shorten that by 7% iirc.
What's the setup?
It would make the gearing awfully short with the 4.11's. You'd be changing gears like an Evo. It isn't the cheapest conversion to do.
Like he said what's the set up?
Set up is an r34 gtr getrag 6spd gearbox fitted to a 32 gtr .. it's the whole box including everything needed to do the conversation
By setup I meant what's the engine/turbo combination.
Boobee. The reason I was asking turbo/engine combo is that (and this is my opinion only) the taller gears in the OS set make a lethargic bottom end of a 2.6 L engine and make it even more pronounced.
For example, a mate on here on a pretty decent R33 GTR put one in and ended pulling it out and going back to stock ratios. That was predominately a track car too. 2.6 with -9's and -5's at different points.
Just something to think about.
Bakemono. Cheers man :D. Be good to drive it again lol.
Oh the lols
only do the Getrag if you do the 3.545 diffs as well, 1st gear in my 34 is now and always was useless even when it was a 2.6 with -7s, so add 4.11s to that and you may as well stay with the 5 speed as you won't use first with the Getrag
I can't wait to see the difference between 4.11s and 3.545s with the two identical OS88s once put side by side :D
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
