  • Replies 77
well my spot is up 4 grabs as I will not be able to make it at this stage :D so PM me
OK OK OK as I said my spot is up 4 grabs $150 1st in gets it :aroused:
& TRUST ME LADYS & GENTS THESE DAYS ARE HELL FUN !!!!!!!! :headspin: :headspin: :headspin: :aroused:
Was a good day. I have a few pics to post once I get motivated. Plenty of GO FOR SIK action. Congratulations go out to Gary1, SLIP and jaqule for there LVMA performance. And a general thanks goes to SLIP for another great day.
Was absolutely awesome!
Cheers to John, James, James, Nexus and Jason (and anyone else who took me out as a passenger) it was great fun!
But Nexus' run for SIIIIK was what made my day at the LVMA, well done!
Well organised Paul, will definately be in on the next one!
Was great fun, despite not being able to bring my own car out this time. I got a drive of the Stagea and scored a few passenger seats though, so it's all good :)
I didn't take too many pictures (spent most of the day with the video camera) but the few I did take are at http://members.optushome.com.au/revhead304.../Skidpan040815/ - warning, all pics load on the main page (ie no thumbs) so the page is 2.5-3.0 MB in size. Dialup beware!
I have 2048x1536 versions of the pics too, if you're in need of a higher res version. Numberplates are visible so you'll have to identify yourself first :P High res pics are are 800k each in size.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
