**R34 GTT STANDARD PARTS:
Bonnet - $325
Front Guards - $350 for the pair
Standard Rear Wing - $50
All parts are factory black, fenders in very good condition, bonnet has some paint scratches on the front left side, standard wing's paintwork has seen better days and is fairly faded on the top of the wing blade (will need a respray).
**R34 AFTERMARKET PARTS:
GENUINE Impul gtt front bar - $650
Replica 34 gtr spoiler with carbon wing blade - $300
Impul front bar is a little rough cosmetically as it had a confrontation with a kangaroo, but won. The paint has cracked and there is very slight frays on the fibreglass around the grill, but otherwise structurally perfect. Will need a respray, but well worth the price considering a new one is $1200.
Replica spoiler has never been fitted as I'm waiting on carbon wing stands from a group buy on here. The carbon blade is very good quality but the standard wing stands didn't align properly with my boot. It's a dead easy fix, but I haven't been bothered to address it.
If the carbon stands fit properly I may keep it (unless the right price is agreed upon)
Pictures will be up soon.
Pickup preferred unless you wanna organize your own courier. Don't blame me as to how they handle the parts in transit either.
Items located in Canberra, ACT
PM for more info and pics.
https://www.sau.com.au/forums/topic/434522-r34-exterior-styling-parts/
  • 6 months later...
  • 1 month later...
  • 4 weeks later...
Hey mate, just wondering whether you would separate the carbon wing blade? Would be happy to swap the factory wing blade (few paint chips) and cash your way. Located in Canberra so happy to pick up. Pm if interested.
Thanks
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
