Hey all!
I recently purchased a '02 Stag as a family car. When it finally arrived from interstate and I had taken it to the local MVR to go over the pits for rego the guy there said that the HID on my low beams are illegal because they don't have auto leveling and the ability to wash the headlight cover.
I am sure a few of you out there that may know or work in the industry can shed some light on this.
The headlights list being fitted with H1 55W 12V globes by a company in QLD I assume at the time of compliance into the country (I will take a pic and post it in a few mins, thought I had one on my phone :domokun: )
I found a level adjust switch in the cabin and noticed that when I had taken it to the MVR it was on it's highest level setting; I think that's what started this whole auto leveling fiasco.
My brother-in-law is a dirty dirty :no: Chaser owner and he has the same setup, HID on low beams with the manual adjuster and has never had any problems with going MVR pits.
Any information on the matter would be fantastic. Even if it's a link to a topic that covers this that I couldn't find.
Cheers!
How are there soo many Stagea's and other imports rego'd and passing compliance if they don't have "auto level" HIDs?
The guy was nice enough to allow me to have 1 month rego so I can get it fixed (also got to put my rims on a diet).
Because complience people are dirty hillbillies.
Cow boys that will blame you for changing it back if you ever get caught.
The guy who complied mine didn't do anything other then put the baby seat mounts and he done a shit job of that. He even complied it with snow tyres on it.
Make sure you keep the setup, and just change the bulbs over so you can change back to OEM. Halogen lamps are not designed for our reflectors and throw a crap light pattern. How dare they force you to ruin such a well designed part of the car.
This!, lol, mine got complied with one headlight working, back brakes on metal to metal and snow tyres, gave the car to them
steam cleaned and polished, got it back with inside back area covered in big greasy patches where they laid to do seat mounts, and greasy marks all over hoodlining..cowboys .lol
cheers
darren
Edited by jet_r31
  • Like 1
Is there an easy way to tell if they have been converted or not?
From that it says they are converted yeah? I'm not crazy?
Halogens don't run on ballasts.
If ballasts are hooked up to the lights, they're HIDs, if not you're fine.
If the ballasts aren't hooked up and they are indeed halogens, just take the ballasts out.... And keep them to install another day :ninja:
Well I do in fact have HIDs.
I was looking at it tonight and going to cut the wires running to the ballast and put a connector on there so i can wire up halogen's when I need to get rego check and if the fuzz picks up on it; but apart from that I will swap out and plug in my HIDs.
But now I have another question; Friday last week the car started playing up (diagnosed to be the Throttle Motor - fixed!) and since then the HIDs flicker one and off like a strobe light. also the parkers flickers (like too much current is being drawn - similar to when you see those ppl with big subs and not adequate power supply). I tested the connectors and they are fluctuating power; between 6 and 7 volts; and I am pretty sure that ain't normal. Just can't figure out why.
Any ideas?
Edited by cabbie_bro
I will check but the in-car volt guage shows over 12v when not running and 14v when running. I didn't even think to test the any other circuits with the multimeter. Also I forgot to mention the high beams don't work at all.
One a related note; does anyone know how to convert from HID to Halogen? such as where i can get the globe terminal from that will fit the Stagea. I am hoping not to hack anything up (except the wiring) so that i can switch between HID and halogen.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
