Sweet as, i figured the spacer isnt terribly priced so i may as well.
Good to know about the injectors, cheers!
The kits from the US do not work on our cars as it is in reverse. Which is fine, i just wanted to use their guide to get a guage on how much work is involved on fitting a kit and how much they actually upgrade when creating a kit.
As far as the air con goes, i will follow your advice, if it doesnt work i will take the other route :P
Ill keep an eye out on turbo's. As i said above, im not doing the kit yet but like anything i just want to get all the research i can, so thanks.
BTW - you missed out on a second hand complete HKS Z33 turbo kit that was for sale on Z club for $2100. It pays to keep your eyes out for the second hand market... ;)
Damn it! I have only just joined that forum! Some reasonable priced parts on there. Maybe ill scout for my coilovers on there :cool:
@Scotty - Nope, not planning on buying the Turbonetics kit. Just using their guide as a reference to see how much is involved with their kit.
2:35. That poor man needs to get a welder onto that diff asap! either that or an LSD.
Nice ride, i don't really like the Sedans but that one is quite clean. Sounds damn good too.
When you say it cost a lot to get 425bhp, he did use a sedan and the Supercharger route. Im not saying it is not expensive, as it definitely is. He did however go for the underpowered G chassis (261hp compared to 282hp stock). Supercharger kits in the US are outrageously priced. $8000 for a bolt on setup that will get you approx. 350whp.
By the looks of it he has quite a built engine also. How much did he pay for the polished pieces?! :D dat shine!
@PN-Mad. That is gold. :P hahahaha
So apart from Rods, pistons and potentially a cam and headwork, what else needs to be modded for a "built VQ35DE +T"?
Nope that's it really. The weak point is the rods. But if you were going to do it, along with above, you'd throw in some decent head gaskets and hardware to screw it down, maybe a HR oil pump which is supposedly better for higher rpm, and flow. Then there is all the gasket kits, water pump, bearings, machining, etc. You'd need the coolant modification, and a decent rad.
There is a guy in the states who also has a fairly modded sedan who polishes the parts. Nice guy. He has polished plenums and most V35 parts in stock. You should see the interior aswell. The car is nuts. Every ARC part they made for the VQ35DE is in that car.
+1
If you have the cash now, I've seen some built engines for sale $6000 to $7000.... kinda cheap. Probably a better option than building yourself.
  • 1 month later...
In reply to the earlier comments. I am thinking of mounting the turbo in a forward position as it looks like the room is going to be VERY limited in the stock position.
I will look at getting the Manifold extended like this one: (not as high but further forward)
More like the positioning of this setup:
And then plumb the waste gate back into the exhaust like this:
Would there be any benefit in using 3inch IC piping instead of 2.5? as it looks like most of the Bolt up kits use 2.5 for convenience...
Cheers guys,
Andy
Now for the build. This is as far as i have got so far with the planning. Ive been way too busy over Xmas/NY to put $ into the Skyline haha.
Tune: NZEFI $800-$850
Turbo: Holset 3LD Turbo $400+ shipping
http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-686523897.htm
Injectors: 550cc RB25det $300
http://www.trademe.co.nz/Browse/Listing.aspx?id=685904641
Aluminium Intercooler piping: approx $200 + shipping
http://www.trademe.co.nz/motors/car-parts-accessories/performance/radiators-cooling-systems/auction-686400366.htm
Intercooler: $160 + shipping
http://www.trademe.co.nz/motors/car-parts-accessories/other-accessories/auction-686315039.htm
Fuel Pump: Deatschwerks 320 LPH $155 + shipping
http://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-686820426.htm
Oil pan spacer + oil feed: JWT VQ35DE Oil Pan Spacer Kit $150 + shipping
http://www.z1motorsports.com/350_g35/product_info.php?products_id=2140
Turbo oil feed line: Driven Performance $120
http://www.trademe.co.nz/motors/car-parts-accessories/performance/other/auction-686282369.htm
Manifold: VQ30det Manifold + Cross Pipe etc $50!
http://www.zclub.org.nz/viewtopic.php?t=3754&highlight=turbo
Oil Catch Can setup: Greddy $80 + shipping
http://www.trademe.co.nz/motors/car-parts-accessories/performance/other/auction-687460120.htm
Sparkplugs: NGK Platnium LFR6A-11 $80
Radiator: Megan Racing Radiator $260 + shipping (Apparently not crucial to the build)
http://www.horsepowerfreaks.com/partdetails/Megan_Racing/Cooling/Radiators/-/14878
BOV: $50
Hoses/Fittings: ??
Fabrication for the manifold/pipes: ?? (A friend will be helping here)
So a rough estimate (not inc shipping costs) from the cost i have so far is: $2630 inc. tune
Obviously this price will blow out a bit as other parts/general costs will be added but it is not a bad start.
Edited by andy_cliff
Heh, expect it to blow out quite a bit.
I've estimated about 9k for everything and I've got 6k estimated left to spend. But I've over estimated on a few things.
I noticed you haven't put down a MAF? You going to use Uprev to tune?
Edited by M35woah
I contacted NZEFI (One of NZ's best tuners) and they said that with some of the newer model Nissans like the 350z, 350gt's they are able to tune them without an aftermarket computer.
I will be taking it in for a pre-tune consultation in regards to the ECU as obviously it isnt something you want to bugger around with.
NZEFI are NZ's main stockist for Link computers and i believe one of the dudes there is one of the producers from Link?
son of rajab! 9k?! Do you happen to have a list for your build by any chance?
Quote from the tuner:
"Hi Andy,
Thanks for your enquiry. With the later model Nissans having a CAN bus we typically stick with retuning the factory ECU rather than fitting an aftermarket ECU. This is especially the case for automatics. We haven't done a V35 350GT VQ35DE yet. We've have done several retunes on 350Zs with the factory ECU and like you say your car is essentially the 4 seater equivalent so I expect that it shouldn't be a problem. However, if you want us to be 100% sure that we can retune your factory ECU then you should bring your car in for us to check over before hand. Please let me know if you have any other questions.
Regards,
Walter Larason
I know you can tune the stock ECU... The people that do it are called "Uprev", which is being used by a lot of people to tune with.
I thought 9k would have been standard for any plus T. I've over estimated on somethings and I'm not concerned if it goes over.
I was asking more about MAF or are you going to run less than 5psi? I believe that is when the stock MAF maxes out.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
