so just take some other woman....Im sure wife wont mind
she suggested i take some one else. and if they dont sell i will. but dont wanna go with out her really....
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
