I'm meeting up with 5hiv on Wednesday arvo to get a cat back exhaust fitted and some R34 rims.
At the same time ill probably try adjust the ride height or tackle that on the weekend.
Checked my child restraints and it looks like I only have one so ill probably grab those off you as well Rob. Not sure how they get fitted though?
If the car fails on too many things is it possible to cancel rego and re-rego in NSW? Or do the defects follow you?
I got f**ked at rego a few months ago... got done with window tint, wheel alignment, no child restraints, to low, to loud, wheel spacers, sub :/, not showing my middle seatbelt clip thing, lower ball joint exc... didn't get done with the turbo timer, pod filter, low brake pads, no engineers report for the child restraints witch Trojan did, they didn't check the Db of the exhaust on second check or the track... f**k they were assholes haha
if you get picked up on that just remove the front tint with a hair dryer...
I removed it all :/ getting the glue off the back window is a shit fight!
I wouldn't worry about it to much.. it sounds like you have all the skyline problems.. if you cant do some of the stuff yourself book it into Trojan, great people down there!
I got my standard shocks and ball joint from them for a good price...
Dunno if it was answered, only skimmed through - regarding the boot lining and struts, you'll be fine. I only had the plastic between the boot and the battery shelf, a sub held in place with tie downs, that's it. Also my struts might as well have not been there lol
Awesome, well I'm going to give it a shot because that doesn't hurt. But still can anyone give info on if I de-rego and then re-rego in NSW would I have any issues?
Only thinking because my parents live down the coast and there are plenty of workshops down there who would allow me to rego it. Could easily chuck it in my parents name for the next 3 months
will need blue slip here so depends on who you take it too will confirm how hard it is.
Just booked it in for the 12th of December :D
So I have some more time to hopefully receive my new car.
Had a chat with the bloke and he said if it fails the inspection then I have a month to get things sorted.
That should allow the time for my R34 to show up MAYBE.
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
