at this stage most likely an evo of some sort...
looking to downsize money in cars and put more into property, and go back to just one car, so want something fun, i can drive daily, has abit of space (4 doors), is fast and can go to the track inexpensively... evos seem to fit the bill pretty well with the price range im looking at, i know it wont be the same as the gtr though unfortunately ha.
Congrats Isaac. Probably the nicest 34 I have seen as well. Brilliant choice.
Hi Anthony this is Isaac the guy who bought your car :) yeah I'm extremely happy with it and specially how well it was looked after, been told by my mates and mechanic that it's probably the best condition 34GTR they've seen . Looking forward to catch up with some of the skyline forums members when they're going for a cruise.
Ha! Gaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaayyyy!!! lol
yea always been more into evos than sti's
haha bring it on!
:P
Will be good to get out on the track with ya man!
Hahahahaha love sti's. Engine is a bit lower down. And handles better with all assist off I find.
But this debate can go on and on. Haha
I've done a clutches, engines and timing belts in both, subaru is a lot easier in all accounts
Im talking modification wise evos are a lot easier. Subarus are shit. I once took a round about in a STi was understeering nearly climbed a kerb as with the evo at a greater speed took it like on rails.
Lol the Evo and STI battle still rages on.
One thing is clear though.
and i just cannot AGREE MORE! LOL!!!
The battle never ends - was lucky to compete in a hillclimb couple years back with a GC8 with DCCD and also had some fun with an EVO - personally i find the Sti's nicer to drive... The evos without any electronics can be a handful.. Agreed on making power on the EVO much easier...
But in the end - its personal preference - either car in good hands - bloody rapid cars...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
