Hi all,
I need to clear out a couple more items that I have been stashing away for my next build as they are simply going to waste on my shelf.
Sadly, this means I have to let go my set of Genuine Mines Super Outlet Pro Dump Pipes to suit RB26DETT.
These are about as top shelf as you could get, incredibly well made and have a nice big bellmouth design for maximum flow, with a 70mm main section and enlarged turbo outlet.
They are brand new, un-used and looking for a new home.
New price is ~$1200.00 + Post
I will let these go for $795.00 firm
Pickup available in North Sydney, or alternatively I am happy to post them at the buyers expense.
Cheers.
My N1 came with these on a complete Mine's system > 319.5awKw running on 21psi and just a fuel pump/injectors upgrade. No restriction at all & really well designed.
There's no loss of RB sound but it is a wee bit different.
Hope this helps a buyer to decide!
Seing you have a R33, I assume its the 32/33 model and wont fit 34 as it uses different MAF sensor plug diameter?
crossing my fingers its the R34 version you have, if not good luck with sale!
They suit R32/R33/R34 GTR, and you use an 02 sensor adapter plug where needed, depending on if your car uses the smaller or larger sized 02 sensor.
Now it appears that there's a new Mine's front pipe f/s too.
Both Blitz' dump pipes & Spring&Water's front pipe here in Sydney > What a pair! > What a saving!
Thanks all!
Someone give these puppies a new home before I decide to keep them.
Will entertain serious offers close to the asking price (given its $500 cheaper than buying them new already!!!!)
  • 1 month later...
Is the 02 sensor adapter plug included? Do mines include it with the product?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
