tom.33gtst Posted November 29, 2013 Share Posted November 29, 2013 Hey guys. My r33 has a slight issue when coming on boost sometimes on long drives. It will cough and splutter just as it goes to come on boost then will clear itself out and take off. It only does this on long drives say driving on the highway for a while then you go to give it a bit and it will hesitate. Around town it never seems to do it. It seems like its running fairly rich as well. Any help would be much appreciated cheers Link to comment https://www.sau.com.au/forums/topic/435721-r33-gtst-hesitation/ Share on other sites More sharing options...
DarkRyda Posted November 30, 2013 Share Posted November 30, 2013 Check the following Vacumm leaks AFM (CRC Cleaner) Coilpacks Intercooler Pipes Fuel Filter Fuel Pressure Regulator Spark Plugs (type / gap) Lower boost (if running above 10-12PSI on stock ECU) Check for ECU codes That's all I can think of right now. Hope it helps, there are lots of threads on this type of issue or something similar. Link to comment https://www.sau.com.au/forums/topic/435721-r33-gtst-hesitation/#findComment-7127539 Share on other sites More sharing options...
Ben C34 Posted November 30, 2013 Share Posted November 30, 2013 qnd o2 sensor Link to comment https://www.sau.com.au/forums/topic/435721-r33-gtst-hesitation/#findComment-7127591 Share on other sites More sharing options...
tom.33gtst Posted November 30, 2013 Author Share Posted November 30, 2013 Thanks for the help, checked half of those things out but ill have to have a look at the rest. I bought a tomei adjustable fuel reg so ill put that on and make sure it's running correct pressure. Link to comment https://www.sau.com.au/forums/topic/435721-r33-gtst-hesitation/#findComment-7127593 Share on other sites More sharing options...
