Thinking about bypassing the standard boost solenoid and installing a turbosmart manual boost controller.
Will this be safe? Buying a new gauge to keep an eye on boost levels.
What can i safely run on a standard turbo, it was rebuilt by the previous owner 15,000kms ago, not sure if its still got a ceramic wheel though..
https://www.sau.com.au/forums/topic/435758-m35-stagea-boot-control/
Might want to find out if it's steel wheeled before winding too much into it, these do run 14psi stock...
If it's highflowed, perhaps the actuator mod is a better start? Be aware, you may start hitting airflow cut if you push too far... Then it's Emanage time.
Yeh better be safe, ill contact the previous owner tomorrow.
Been reading a few theads about it, will switching to a boost t help build boost earlier? Not more just sooner?
Something about the standard solenoid bleeding boost early..
I put a turbosmart boost T on mine and other than the rear section of exhaust it's all stock. Most I've run is around 17psi but got scared after a while and put it back to 14...i think I was getting airflow cut too at the higher boost sometimes. But yeah still run it and prefer to standard electronic one.
Nope, i have driven one that sounds like that though. Does the stock turbo always seem so loud?
Only time i can really hear the turbo is on cold start ups but once it warms up its gone. Just a slight whistle under full throttle.
It will drop off up top as the wastegate spring is just too soft, manifold pressure simply blows it open. That is the reason I modify them with an external spring. There are a few threads on the subject, one owner recently got a turbosmart actuator in there but it seemed like a lot of work compared to the external spring imo.
The spring can be replaced to any tension, or even removed so it runs stock boost again. That is the main benefit of mounting it externally, as you can perhaps change it in situ. Pain in the arse to swap actuators though.
I usually ship it with a 16 psi spring, but depending on the setup, it could run more. Replacing the BOV is the main culprit it seems, that might make it hold 20psi.
16psi sounds fun.. :D
Much point doing all this with the stock exhaust system?
Id like to get a dyno run, make sure all is okay before upping the power. Does Cihan do just dyno runs? Not up to tuning jusy yet. And does he have a contact number??
www.etuner.com.au
I would be changing the dump at least, if you saw one you would laugh. You could barely get a 50 cent piece down the throat, then into a restrictive cat.
He is easy to get along with, just let him know you want a baseline power figure before the inevitable tune. :P
You seem really keen on upgradig the stock dump scott, cant imagine why haha.. ;) but yeh ive seen a std one, pretty laughable.
Yes. Just a baseline figure. For now......
Is an emanage the best way to go in terms of tuning?
    • Do they always do it from the AFM? If so... You know what I'm already thinking I reckon...
    • The other problem is that the pan is on an exchange basis, which would be a pain to have to send original sump to Oz for the work to be done. Would ideally need to be able to pay for a locally sourced core. To that end - I'd just fabricate one outright.
    • Not at all, pure street use, touge, even drag strip and you'll be fine   There's a larger version of it too, however would be overkill for your application. If you do plan on using that sump, might as well fit a headdrain/crank case vent to help alleviate crank case pressure. Your mechanic will also notice you cannot re-use the AWD windage trays on the motor too, as it fouls with the AWD -> RWD sump. However given your usage, you'll be fine.
    • @GTSBoy yeah but the MAIN problem is that "you" guys may know that but i/my mechanic did not. I literally spend hours to find differences between Stagea and Skyline engine (even here) and found kinda "nothing" Yeah one guy mentioned that the block is larger/wider but nothing about the oil pan. Of course AWD has different one but "everybody" says...yeah just slap RWD pan... and the parts number for my N/A engine and NEO DET were the same so iam using one from my old engine. And of course being in EU/Czech many of the sites did not even show(i need VPN to be here)... @MBS206NO it is not my channel and not my video. Dont even know the guy. I just post this as a reference cuz i have the same problem. As i said you guys in AU/NZD may know this but here it is kinda a new info cuz IF someone doing this swap they already have oil pan or they make custom one.  @Dose Pipe Sutututu Yeah it is AWD RB25DET NEO Yeah as you mentioned the pick up is in a different place ...but i do not drift or track the car. It is and will be strictly street and just "casual" weekend cruiser. With that "custom" pan as shown in the video...could there be some problems?  For others. Iam sorry if that topic "looks" like i want to show/boost some YT channel or numbers. Iam quite the opposite.  I would rather drive my car thru sewers than get the attention that this car gets here. I do not have any YT channel nor IG/Twitter or TikTok. I just want some info from time to time cuz here...there is none :-)
    • +2 Mine came with a bonus flat battery.
