RB25DET
Changed out my series 2 motor with a series 1 motor due to a failing bearing. Motor is still physically okay, and running gear that has been removed is working
I have the following parts available. Pickup from Dandenong VIC or I can post at buyers expense.
Starter motor - $70
Alternator - $80
Power Steering pump - $80
Throttle Body - $80
JJR Dump Pipe to suit standard turbo (6 bolt Nissan rear) - $100
post-59604-0-81054000-1386481502_thumb.jpg post-59604-0-43354000-1386481535_thumb.jpg
Standard log manifold - $150
Standard RB25 blow offf valve $80
Timing Belt Covers Top & Bottom (painted blue) - $100
Fuel Rail - $50
Xtreme Heavy Duty Cushion Button Clutch (80%ish meat) & Pressure plate - $400
post-59604-0-66551600-1386481775_thumb.jpg post-59604-0-94193000-1386481804_thumb.jpg post-59604-0-57406800-1386481832_thumb.jpg
Coilpack bracket (S1) - $25
Coilpack harness (S1) - $40
Ignition Module (S1) - $80
Injector harness (S1) - $40
Crank angle sensor (S1) - $150
Oil Filter Housing [between block and filter] (S1) - $70
Set of 4 White Yokohama Advan TC2 rims. 18x8.5 +25 front / 18x9.5 +29 rear. Stud pattern 114.3 x 5. light weight 8 -9kg.
The front rims have Advan AD08 tyres 245/35/18 on them, the inside shows signs of camber wear so those tyres would need replacing very soon, however they still appear very grippy. The rear rims have Nitto NT05 tyres 275/35/18 on them which are completely worn and need replacing.
The front right has a small crack in the rim (on the middle part where the tyre is seated) which has just temporarily been repaired but will need a bit of welding. I got quoted approx $110 to have it fixed.
The front left rim has some light gutter rash on the outer edge of it, but it should be fairly easy to clean up.
Other then that the paint and rims themselves are in good condition
$1800
post-59604-0-41477300-1386482459_thumb.jpg post-59604-0-77908300-1386482489_thumb.jpg post-59604-0-13562000-1386482516_thumb.jpg
SMS me on 0458762075
Brent
Have you still got the whole head ?
Sent from my iPhone using SAU Community
Hey mate, I just sent you a PM. I have it still. I sent my phone number in PM too.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
