For sale:
2. 0-250 PSI stainless steel pressure sensors - fuel / oil pressure.
3. 0-1000 PSI stainless steel pressure sensor - good for automatic transmissions
Item Condition: All new, were installed to engine but engine was not running at any time.
Price and price conditions: Pressure sensors are $150 each, MAP sensor $140, temp sensors are $30 each
Extra Info: The pressure sensors use the 3 pin delco TPS style connector. Only the 1000psi sensor has the pigtail included. I will include a connector to suit the MAP sensor. temp sensors do not have connectors either. Connectors with pins are about $8 each from EFI hardware.
Pictures:
Item 1:
Item 2:
Item 3:
Item 4:
Item 5 and 6:
Contact Details: PM
Location: Gold Coast, local pick up welcome from Robina area.
Delivery & Conditions of Delivery: $5 per sensor.
https://www.sau.com.au/forums/topic/436310-fs-pressure-and-temperature-sensors/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
