Ive come to a bit of a halt in my auto to manual conversion. Would anyone have any images, diagrams or step by step procedures to help me. When it comes to wiring, things for me get a bit messy, id love for someone to shed some light on me.
BASICALLY, my question is, "How do you bridge the reverse,neutral inhibitor wires etc".
Im still learning, so i am quite a noob :)
Yeah you cant bridge the reverse plug or your reverse lights will always be on.
I agree with above, best way to do it. From memory the transmission loom unplugs around the starter motor, so its not to bad to swap
You would probably need the plugs for the neutral and reverse sensors, assume the speedo one is the same but not to sure
Would have to cut the old plugs and solder/join the new ones in. But having never seen the auto sensors, cant comment how different they are
