There is a seller on ebay (northside nissan) selling GTR Parts including a rebuilt gearbox...located in WA.
Prob not from the same car OP is talking about . I actually bought a used GTR wheel centre cap from them- happy with their service! :) I just found it a bit of a coincedence that its a rebuilt GTR box for sale in WA from a Nissan dealership...
http://www.ebay.com.au/sch/m.html?item=271334208534&ssPageName=STRK%3AMEWNX%3AIT&_ssn=northsidenissan&_sop=16
Edited by Dane
https://www.sau.com.au/forums/topic/436589-gtr-scam/page/3/#findComment-7265289
Yes both. The report from Nissan indicating there was nothing wrong with the car was provided a few hours after I handed the car over. The exact same report that apparently indicated the transmission required a full rebuild when it was done for me.
There is no doubt that something in there broke. The noise was horrible when it happened and I have the broken part of one of the shift forks in my possession.
https://www.sau.com.au/forums/topic/436589-gtr-scam/page/3/#findComment-7265474
  • 2 months later...
I want to clarify a couple of points here.
If Nissan told you that the shift fork broke and it's to high in the gearbox to see well that is complete and utter garbage. If they had the valve body out then the shift forks are staring them in the face, right there you can move them with your fingers. If the selector broke it would fall on your damn face when you removed the valve body. I can't believe that is what they would say.
It is possible that the broken part could have jammed the selector pistons and that is why you had no even gears. Once the broken piece fell out and all fluids were replaced and a clutch relearn was performed it is possible that the car could still drive and shift with 1/2 to 3/4 of a fork. It's not good but potentially it could still shift.
Almost all R35 trans issues can be fixed for under 5K including parts and labor, that includes trans fluid as well. There is nothing to fear here. A selector fork is a little harder but you will definitely still get away well under 10k. I have a complete R35 trans on the shelf here I would have changed over for you for under 10k. These prices are out of control, you can't go to Nissan it's just not worth it.
Edited by g35me
https://www.sau.com.au/forums/topic/436589-gtr-scam/page/3/#findComment-7320712
Also a potential answer to the question is that Ford traded your car for next to nothing because of a 47k invoice for repairs from Nissan, they then took it to a competent workshop who bought a new trans for 15k they then swapped the old trans for the new one in around 3hrs as that is all it takes and by lunchtime they had it back on the lot ready for sale and it technically has never been launched. Honestly that is all to easy. And all the talk of trans mated to engines is garbage too.
  • Like 1
https://www.sau.com.au/forums/topic/436589-gtr-scam/page/3/#findComment-7320713
  • 4 weeks later...
All very well. You're missing the point though. They didn't change or repair the transmission. I called both Nissan and Ford management regarding the issue (abused them too) and they just defended their conduct. I have emails to prove this.
It doesn't bother me at all, I had fun with it, but it's not fair on the poor guy that pays $100,000 for a car with a problem that's going to cost you extra money you didn't interested to spend. If I could help them out I'd be happy.
I'm no GTR technician, but I asked which shift fork is broken so I could source one myself. I was told they didn't know because you cand see that far back in the transmission. I could only guess it was the first fork from the broken tip I had.
https://www.sau.com.au/forums/topic/436589-gtr-scam/page/3/#findComment-7342618
  • 4 months later...
Sounds like both you and the new customer got duped by asshole dealers. I worked for them here on the GC for a few months. I left way dodgy, could not look people in the eye and give them the spiel they wanted us to do.
Somebody should make a list of none Nissan dealers- that can service the R35, and if customers, both Aussie delivered and import alike started tailing there cars there maybe they would learn there lesson.
Regards,
Todd
https://www.sau.com.au/forums/topic/436589-gtr-scam/page/3/#findComment-7444702
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
