Found this in my tyre, it wasnt all the way in cos there was a plastic head, see imprint in tyre.
The bottom part looks like it was into the belt as its chewed up.
Im wondering how much rubber is left at the bottom of the hole? And when will it leak?
post-89755-0-80618000-1388382663_thumb.jpg post-89755-0-95954500-1388382692_thumb.jpg
So i can put a plug in there, but i dont want to put a hole if i dont have to.
Opinions anyone?
Oh.. and i use these tyres at Wakefield, i get about 160 down the straight.
Edited by D.I.Y. Mik
Get it plugged. You may have <1mm of rubber sealing the hole, or it might be fine. You can't really tell, and you wouldn't want to find out at the end of the straight would you?
What GTSBoy said.
A few years ago I hit a screw a few days before going to Wakefield, did some research and ended up buying $50 plug kit (which I haven't used since) and fixed it myself. Tyre lasted until it ran out of rubber months later
In hindsight I should have just paid a tyre fitter to fix it, but in the end I still did my track day :)
get it internally patched, the plug is only as good as its installed...
I dont trust a plug until it has gone some ks and even then its in the back of my mind...
Hmmm... yeah. its a worry.
Thanks guys.
Internally patched sound pretty safe, better than a plug you say.
Sounds good.
I have lots of plugs but ill play it safe.
Stockies back on till its fixed.
:thumbsup:
I bought a plug kit years ago and have used it many times.
Once i remember my sons freind brought his car over which was making a loud banging sound and bouncing while he drove it.
Ended up being a screw driver he ran over, went in all the way, just the bent handle sticking out, the plug still fixed it, still going strong for the last 2 years.
Yeah, the plug is easy, ive got plenty, and the tools.
Used them heaps myself, as im a tradesman, ute on a building site gets a few every year.
Its just that it may not be good enough for 160kmh with hard braking and cornering at Wakefield.
Better safe than sorry i say.
And ive learned that the hard way.
I personally wouldn't take a plugged tyre on the race track, would be fine for road use though (in fact one of the cima's tyres needed a plug the other day).
plug and retire them to road use...
Best ones I know of are called a donkeys dick . Basically an internal patch with a rubber stalk in the middle you pull out through the hole . Vulcanising patch also held in place with inflation pressure and a plug to fill the hole . Dunno about good at track speeds though .
A .
Hmm... not keen to retire them for road use as they are near new.
I think further research is needed.
Oh jeez where too look, cams maybe.........
Ok found this:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=77
Answers all my questions.
New tyre is what i need. Expensive....... damn. :rant:
old topic but at work I use the plug kit all the time (royal Canberra gold course) on the quad bikes and mowers, not that the mowers go quick, but the work quad is a 600, kinda the workshops emergency response vehicle haha, all the tyres on it have like 20 repairs, on 40 psi, I have personally been about 90kph on it, had to get a to the excavator to get his truck unboged before the stupid royal f**ks started playing golf... I have only had one plug come out before, didn't let it set before riding the quad...
A .
Agree. I love those donkey dicks lol. 10 times better than just a plug or just a patch. You get both. Also work up an extra set of wheels and rubber for just track. Keeps good tires good and others to burn off. It's an investment. Here's a donkey dick. post-116132-13908576243971_thumb.jpg
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
