Invoices go out on Saturday. Pay have and follow the instructions on the invoice please. I have no way of tracking these without the invoice number.
Can I get a rundown of the GPS Tracking + Paging. What Sim Card to buy, $30 dollars that is unlimited time or what? How does it all work? Does it use Google maps or another program? How accurate is it and how quickly does it refresh?
Since I've received my invoice but you haven't replied to my message. I'd also like to know how warranty works? Hypothetically what happens if the unit shits itself within the first or second week? Who repairs it and at who's cost?
Cheers,
Borci88.
SIM card , Telstra do a SMS package that debits your bank account. You need that one. Vodafone also do them. $5/ mo or so.
Warranty taken care of by the local dealer there. Warranty work won't be required though as these do not break :) regular maintenance on it though will be required. The pin switches do corrode over time. The rest though is solid.
If you have questions - call me. I'm not on here daily as currently I do not get time to.
I average 100-200 calls a day and barely get time to get jobs done. (Phone is getting set to divert once this trip starts)
Email is the other way to get me.
23/01/2014 Direct Credit JONATHAN NGUYE N Jonathan5793 $377.00
23/01/2014 Direct Credit SEBASTIAN GIUL IA Sebastian 5790 $344.50
23/01/2014 Direct Credit MY NGUYEN Eric Tchung 5788 $754.00
23/01/2014 Direct Credit TIMOTHY MUMFOR D mumford 5787 $690.00
23/01/2014 Direct Credit SHIVAM ROHIT Shivam5791 $659.00
Missing 2 . I know why I am missing one of the two what about the other.
Stock organized btw. Did so Friday.
emailed (got busy)
Stock here - ships monday.
updated list.
29/01/2014 Direct Credit ALVIN SIEW xALmoN 5789 $400.00
find your postcode. some of those left today some are going in now.
the two honda guys. going to do OEM locks on yours as well.
is this your car?
1998-2000_Honda_Civic_CXi_3-door_hatchba
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
