Hi,
Just picked up a 2004 M35 350RX Four
Its a marked improvement on the pulsar and good to be back in a car with some power since selling my Autech S15
Just wondering what "security" this has, it has a flashing light, but is that all it is or does it come with an immobiliser etc as standard
also wondering if anyone can tell me what this is/does?, located to the right of the steering wheel under the security light
I would also like to get the trip computer translated into english but the auckland contact from the youtube vid on the xanavi website no longer does it, is there anyone who does it? or am I shit out of luck?
Cheers
https://www.sau.com.au/forums/topic/437398-new-m35-rx-four-questions/
That appears to just have the alarm fitted by the dealer which is part of the wing mirror fold-in option, usually the cars have a second LED above that security one which is to do with the smart keys and immobiliser.
Do you have smart keys?
Edited by M35woah
Cheers for that info PN-Mad
It does fold its mirrors when locking the car, but it does not have smart keys unfortunately.
Mine has the same security light (no sticker). Do you have a T shaped object in the middle of your dash near the windscreen by any chance?
My car also has Nissan factory security. It has a different light (just above the one you pictured) and is part of the moulding... as well as a large grey sensor on the passenger A pillar.
hmm, need to see the factory options catalogue to see if it was in there.
We couldn't find any alarm/security error notifications or a reset option on mine when it was on Consult (my car was broken into on NYE and the "security" led has not stopped blinking since).
Nope I don't have a t-shaped object or the sensor on the A pillar, must have been a couple of levels of "security" from the factory.
Sorry to hear your car got broken into, i can remember finding glass months after my old car got done over.
There's a guy advertising on TradeMe who does translations for Nissan screens, can't remember the keywords for how I found it though, sorry.
Hmmm that sounds interesting, can't see anything on there at the moment but will keep an eye out. I have found a couple of NZ companies that say on their websites that they can convert the nav to NZ maps for all Jap models so might look into that too.
I have two!
The security one as pictured above, and another separate blinking led just above it.
Yup, the one above I believe is to do with the immobiliser and smart key. I think that one is a factory option. V35 skylines with our dash unsure what series it is but they have the little blinking LED in where the clock is.
Nothing was in there, not even the cup holders lol.
They did give me a broken window and dented door frame though. That bloody glass gets everywhere!
Sons a bitches! Sorry to hear it Cam, you need a car dog, one that lives in yo car.
Edited by M35woah
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
