This stuff needs to go fellas, no reasonable offer will be refused.
4. R32 stock intercooler and piping - around $50 make an offer
5. R32 horn - $10
9. R32 steering wheel. fairly good condition - around $100
all prices are pick up. Can post at buyers cost.
in Sydney (Inner West).
https://www.sau.com.au/forums/topic/43740-momo-wheel-gauges-r32-gts-t-bits/
mate would u accept 350  for both gauges the sony6x9's, the amp and the subs
sorry mate but that's a little low. Ive already got an offer of $180 for the subs.
the boost gauge is 60mm and the AFR is about 40mm. gauges are in decent condition, the AFR is very good and the boost is passable (it works without a glitch).
no centre cap for the steering wheel.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
