Hey guys just a quick one, I have been using Castrol Tranzmax Z Fluid in the gearbox, normally just go to peps and just order it but this time they said that they need the gearbox number to order it?? They said something about having to confirm the gearbox number with nissan 1st due to a number of stolen boxes. Can anyone shed some light on this please.
https://www.sau.com.au/forums/topic/437554-issues-getting-getrag-fluid-r34-gtr/
That's the biggest load of crap I've heard.
Would have told them to just sell it to me, or I'm going to walk and buy else where from now on.
They are an auto shop, not the police.
Actually, wasn't there a case of some gearboxes going missing from nissan a while ago? Or am imagining this?
the story you were told makes absolutely no sense. maybe report it to the store manager
transmax Z is not a Nissan fluid, it is a fluid that can be used in nissans or other suitable vehicles
Remember mate, it is your money you are spending, so spend it wisely. If something doesn't feel right, or you have doubts, walk away. There are other places where you can get the same thing. A business exists to make money, why should you give them your money when they are stuffing you around?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
