Today when I was coming back from work my power steering just stopped working suddenly. The HICAS light also turned on a few moments later. It is a r32 gtst with a rb25deneo . Checked the fuses and power steering fluid and it all seems fine. I turn the car on and drive for a few seconds before the power steering gives way. So initially the power steering works when I turn on the car.I took it around the block a few times and the hicas light didn't turn on ( was only driving for a couple of minutes at a time). I put on a aftermarket steering wheel on a week ago but never had this problem. What could it be ?
The aftermarket steering wheel is the problem
Unless it accomodates the steering wheel angle sensor the hicas aint gunna like it. .when I got my R32 gtst the hicas light was on ... the(stock) steering wheel had been taken off but when it was put back on the dot on the column and dot on the back of the wheel werent lined up... . Lined them up.. reset ecu, no light
Some race day guys just cancel the power steering. With the old rack. Steering feels like a go cart but its fine, not that much of a difference. No more leak problems and sensor crap anymore.
there is only one way you can put the boss kit on to line it up with the horn clip. I never took the lines off the hicas bar when the changed the diff i only took the two bolts off. Like i said, the when i start it it initally works but then stopped after driving down the street. i might need to do a diagnostic test on my ecu. my mechanic who even put the engine in didnt really have a clue really
OMFG just spent the whole f**king day trying to swap over the pump and guess what...IT DIDNT DO JACK SHIT!!WHAT A WASTE OF 6 HOURS AND $160!!! ANYONE HAVE ANY MORE IDEA'S? I cant be any clearer, it works when i start the car and drive it for 10-20 second...i can turn the car on and leave it on idle forever and the power steering will work...but it stops after driving...the HICAS light comes on after about a minute or 2 when the power steering stops working.
i had enough of these jdm's man...too many headaches and its making my wallet empty!!
Did you do the hicas diag?
alright the HICAS light comes on, then 4 quick flashes before the HICAS light stays back on, then 2 quick flashes then the light stays on, then 1 quick flash before it stays on again. It repeats this and you can hear knocking noises coming from the back of the car.
Edited by IM-32-FK
  • 4 weeks later...
Unplug the smaller plug from the HICAS computer and see how you go.
alright, i did that, and the power steering worked for a few seconds before shutting off like usual. Could it be that the smaller plug has gone and needs re wiring?
Doubt it's the plug. Take the HICAS computer out and have a look inside, there might be a loose screw or bad solder joints or something. Mine randomly craps out and it's pretty annoying. Makes me wish I bought an R33 GT-R :(.
My car does this some times if I don't warm it up enough. when I come up to a stop the power steering stops, HICAS comes on and it try's to stall and a banging from sound comes from somewhere it's got me f***cked what it is.
i already tried putting in a working hicas comp and the same thing happened. Maybe it's the hicas position sensor behind the steering wheel?
And Dylan, that noise might be the diff because when I do hicas diagnostic the noise comes from the diff Edited by IM-32-FK
i know its got something to do with the speedo because i read it on other forums. Like i said the speedo doesnt work anymore as well. I had to get a custom speed cable because its a neo in a r32. I took the cluster off and the needle behind the speedo wasnt snapped or anything, but i dont how its supposed to operate when its working and when its not. Someone please point me in the right direction
Edited by IM-32-FK
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
