For sale are some rb26 parts, as i'm putting the standard parts back in before selling my r32 gtr, to fund my new bike and super-motard setup for this year.
Posting from townsville.
Contact
email: [email protected]
text: 0434916740
NEW Supertech Pistons 86.5mm/8.5cr
$550
All parts below have done just under 8000km.
HKS Stage 1 cams with unknown adjustable cam gears
$500
Tomie Dump Pipes
$400
Spool Rods
$450
Ross Tuffbond metal jacket balancer
$400
Mines cam Baffles
$200
Fuel Rail & Aeroflow fuel pressure regulator
$200
RC Fuel injectors 750cc with clips
$400
Nismo rb26 oil pump
$800
Supertech Dual Valve Springs With ti-retainer
$400 (also comes with inner washers to go between head and spring)
Old Oem Valves
$ make a offer
https://www.sau.com.au/forums/topic/437762-rb26-parts/
  • 1 year later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
