Ok Folks
My recently acquired Racing Red Suzuki Swift (1992 GA, 1Litre - 3 cylinder, 36kw of killer power, 5 speed) is up for sale - or hire (while your skyliner is in the shop).
I've decided to name her Angry Bird due to the fact I found a Red Angry Birds steering wheel cover that matches the awesomeness that is Swifty in Repco
The engine be very strong and has had work done to it and the gear box - recently. (Don't know what but all gaskets etc new)
For the last week I have:
- New exhaust
- New Windscreem
- New Century Ultimate Performance battery
- Fully serviced - Iridium Plugs, OEM Filters & Fluids. (includes engine and fuel system flush)
- Obtained RWC (ready for Rego which I'll get 3 months put on)
- Tyres look new (put new hubcaps on)
- Complete and full detailing (2 full days my effort :( )
- 650 kms per 40 litre tank - cheaper than chips to run
- Canberra car all it's life (no rust etc...)
- NO accident history - Straight as
- Oh and a New Sony Explode head unit with remote
Now I got it for F.A. off a neighbour but have spent just under $1400 on it (which will include the 3mths rego).
Genuine SAU folk - $1600 (your going to be driving it - and I'll check farkers !)
Friends, Family & Randoms - $1800
I'll Hire her out for $100 per week while I wait to offload her (plus fill it up on return).
Spotters fee $100 on Sale :D
:cheers:
This bitch be worth it
Cheers
Richard
Quality pics to come but here's one to start
(the bonnet is released - not a friggin panel gap ok)
Edited by Sinista32
If you own a Skyline and/or your modifying you know what ! your going to need something like this :yes:
or if you have one you can't park and leave for the day
Come and see it, you wont believe how good it is .....
Get amongst it quickly
Cheaper than a set of good rims and for this price you get a Rego'd car :woot:
Edited by Sinista32
^thought it was kitty litter at first :P
so had good fun driving the Swift out to the Friday night meet last night.
As I was leaving got the sign to light up the tyres on the way out ... yeah right, not likely
Lulz were had I'm sure, hehehe
Takes the worry out of getting pulled up on the way home mate .. :ninja:
I see red, I see red I see red
That's right. Split Enz classic song about this very special Red Car
Do you know some cute chicks in need of a great looking reliable ride. (Ideal for L/P's)
Give them my number ;)
$1600 drive-away no more to pay
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
