[Vic] Gripshiftslide / Import Monster - Summerdays & Enginebays #2
We're teaming up with our good friends at Import Monster to throw another killer street party.
Onsite there will be the usual affair of market stalls, RC Drifters, BBQ and a DJ.
Come down and join the fun.
see photos from last years event here: http://gripshiftslide.com/2012/12/06/gss-x-import-monster-summerdays-and-enginebays/
WHEN: 2nd February
WHERE: 4/2 Clare St, Bayswater, Victoria 3153
TIME: 12:00pm until 4:00pm
MORE INFO:https://www.facebook.com/events/1451013998446019
*Remember this is a public event and you must obey all road rules while in attendance, any bad behavior will be recorded and forwarded to the appropriate authorities.*
postponed till 2nd march?
Yerp.... ain't nobody gonna hang out for hours outside in 41c heat... at most they might swing by to check it out, then leave. Events like this only become massive and awesome if people hang out for 3-4 hours.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
