Quick question,
I've just got new injectors and fuel rail - the rail is red because it was cheaper and in stock, can someone tell me how visible the fuel rail is under the std inlet plenum?
Just trying to figure out if its worth me painting or not. Everything else in the engine bay is black (even intercooler pipes and joiners) so I don't want a easily visible red pipe sitting in the middle of my engine.
Cheers
https://www.sau.com.au/forums/topic/437975-unwanted-wnk-factor/
Keep it red. Fuel is dangerous and flammable, firetrucks are red for a reason, and your fuel rail should be too. Surprised they're not that color from factory.
At first I agreed, but then realised fire trucks don't explode, now I'm really confused!
You couldn't just look at your engine and judge how visible it's gonna be?
It's definitely visible, and more so if the rest of your engine is black.
My engine is in pieces and has been for almost 3 years. If there was an engine to look at then obviously I would have looked....
And yes i have googled many times. If you google rb25det and rb25det fuel rail have a look at the thousands of pictures of cars WITH FORWARD FACING INTAKES or cars with std rails or simply the rail by itself.
The images don't help me at all - hence the post. No need for smart ass remarks, was a genuine question
Ill give it a scuff and coat of paint tonight, cheers
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
