Hey guys, a mate and I are starting a rebuild on his 33. Last engine threw a rod via big end fail, 3 holes in the block and a severely damaged block drifting at QR. M
Want some thoughts on this package, main goals are 300+ kW, it will be a drift/ street car but more drift, he does like to rev it quite hard.
Specs now:
3076 turbs
Wold 3d V500
540 injectors
Front mount
Stainless manifold
Full 3 in exhaust
Split fire coils
Fuel pressure reg, surge tank
Rebuild part list so far ( please give comments and thoughts, nothing is bought yet)
All ports matched to gaskets
N1 pump
New water pump
ARP main and head studs
Cometic gaskets
Cp pistons
Eagle or Manley rods
Tomei Poncams 256
Adj ex gear
Baffled, and larger sump
Oil cooler
All ports will be gasket matched, oil return line and ports enlarged/ cleaned up. Crank balanced, all pistons & rod will be balanced. Block needs to be bored and honed, still unsure about wether it needs to be decked. Any othe suggestions?
Cheers
https://www.sau.com.au/forums/topic/438239-rb25det-engine-rebuild/
Why wouldn't you deck it? It would be at a machinist anyway, and hardly costs anythings to do.
The port matching to gasket is pretty much pointless, typically the gaskets are a reasonable amount larger than the ports, so you would just be doing this
___/\____ (gasket goes between slashes, makes more sense in my head than on the screen)
Hacking shit up and making it worse with a die grinder is easy, improving the flow characteristics of a port is really hard.
If you are fitting an N1 pump and like to sit on the limiter read at least the last third of this thread:
http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?&hl=sk+oil+control
Stay with stock pump or if you want just upgrade the gears in them, Im personally still using stock engine stock oil pump with 350kw last 3 years in my drift car and no problems so they can take the abuse.
Will only deck the block if it needs it, can't see a reason to just deck it. More with the gasket porting is Exh, oil, water. The rb25 heads flow more then enough for what we require. However one of the engine builders recommend it so that's why I was asking here.
Stock pump was trashed and picked up a new n1 for almost free, still looking at changing gears in them. Definitely fitting a crank collar.
Yeah have spent the last couple of days reading that and plan to do sump vent, restrictors and possibly look at .cam cover baffles
Yeah we were thinking of just staying stock, everyone says they are fine at that power but then this is also just ticking the boxes for later, we aren't really doing much headwork yet. That might come later, most probably will.
internal or external gated?
are you planning to stay with 540cc injectors? seems small
Still tossing up going e85 so that will mean complete fuel system change. Also fairly happy to keep 540's in for the run in phase and if it becomes a problem upgrade then. Injectors aren't to bad to change after the fact, it's more bottom end we are focused on ATM.
Internally gated ATM, not sure weather it's worth changing to externally gated, have to do more research.
I'm getting 314AWKW at less than 90% duty on 98 petrol from my 550 Deatschwerks so you should be fine for now.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
