Warning Name
Warning Description
Warning Points
Off-Topic
Any off-topic posts made.
2
Chatting
Any chatting in areas that do not allow chatting (such as the for sale area)
3
Trolling
Attempting to get another member to 'bite' so as to argue with them
5
Trader Rating Abuse
Anybody not using the trader rating system properly
5
Pr0n
Any adult material posted on the forums
7
Personal Attack
Name calling, threatening - anything which is aimed directly at another member with an intent to cause harm
10
Once you reach warning level 20, you will be banned for 14 days
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-895925
how does one know if they've been given a warning? I assume email, but just checking that you do get notified of them. Is there a way to check my personal total/tally of warnings?
...And 99% of users (everyone without any forum authority) have these links to warn and view with no purpose but to be told that they don't have permission. Or is it just so everyone's aware of warnings?
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896225
I was given a warning in the QLD events section for mentioning another car club/forum.
It wasn't for mentioning another car club/forum Matt...
It was for trolling... See above for the description of trolling...
You've been asked / warned before about this exact thing so don't play dumb...
Happy to talk to you on MSN about it...
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896508
yes you will be notified by PM if you are warned....its just a system to try and keep things under control....if you accumulate 20 points you get banned automatically for 2 weeks.
Is there a use by date with the warnings? I dont think its totally tragic if you accumulate 20 pts over 18 months to 2 years for example.
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896963
Ok,
I dont agree it was trolling...
Will have a chat in private mate.
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-898779
Who administrates the administrators ??
Moderators do. We recieve warnings just like the rest of you.
Regarding checking points - you can click "view your warnings" under the Quick Links menu ^ up there.
This is just going to be a fair system for people instead of mods personally PM'ing somebody twice about the same thing etc... just helps us keep up to date with it.
Regarding the links - I will mod that so that only the mods who mod that section can see it.
Thanks - any other q's, post em here.
Christian
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-899149
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
