Hi guys,
I'm having my cam covers soda blasted and therefore wondering about the removal process of the cam cover baffles and how I would reinstall. Seems like a silly question but I did not want to break any seals or effect anything which may be inside the baffle. Is it as simple as removing screws and lifting out? Thanks for the help in advance!
https://www.sau.com.au/forums/topic/438727-rb26-cam-cover-baffles/
Remove the 8 (or was it 10??) screws holding the plate onto the cover. Lift the plate from the cover. May require some gentle force to lift off because the silicone used to seal around the edges might stick on to it. Lift out the gauze (little metal wire thing that sits between the baffle plate and cam cover). And that's all of it removed.
When you re-install, try to remove as much of the old silicone that sealed the plate to the cover as you can. Re-apply some auto grade silicone around the cover where the metal plate sits onto. Re-install the metal gauze. Place plate onto cover and tighten bolts from the middle 2 working outwards being careful not to over tighten them as the covers are alloy and it can be very easy to strip the threads.
Edited by Chris32R
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
