Located in South Australia, Pick up welcome, happy to post anything interstate at buyers expense, prices are negotiable but be realistic guys & girls these are all genuine items no fakes or copies. PM, call or sms 0402072466 thanks :yes:
Genuine 100% Titanium Power house Amuse R1 Titan Cat back exhaust, direct bolt on for R33 GTR & Gts-t, with a little modification it will fit onto R32's & R34's. 90mm piping diameter & 130mm tip. this exhaust cost me $3000 it is less than 4000kms old. weighs about 6kg, i had an AM performance 400mm mid muffler/silencer put in less than a month ago that cost me $650...its a straight through design so it does not change the flow at all! On a top mount turbo'd RB25 with a hi flow cat at 4000rpm the exhaust used to measure 105db but since the muffler its now just over 91db... sounds very tough & unique, i still have the piece of titanium we cut out so if someone wants to make it ridiculously loud again they can just have it welded back in. Price is $2,100 O.N.O pm call or sms 0402072466 (ps The pictures are before i had the silencer put in)
post-30634-0-80015900-1391659814_thumb.jpg post-30634-0-71028000-1391659822_thumb.jpg post-30634-0-27508900-1391659830_thumb.jpg
post-30634-0-86713500-1391659838_thumb.jpg post-30634-0-70051500-1391659847_thumb.jpg post-30634-0-77386700-1391659871_thumb.jpg
Genuine HKS 3037s (external gate) 56T .73 Rear Housing, Its just under 5000kms old & was ceramic coated by Ceramic coat Australia in Richmond S.a It flowed over 300rwkw on pump fuel very good balance between power & response, price is $390 O.N.O pm call or sms 0402072466
post-30634-0-34476400-1391657199_thumb.jpg post-30634-0-44417200-1391657212_thumb.jpg post-30634-0-69486500-1391657221_thumb.jpg
Genuine pair BRIDE Brix II seats with Bride RX Type rails, less than 5000kms old, in absolute perfect condition always treated with the utmost care & meguiar's leather conditioner, No rips or tears at all. will direct bolt into every R32 R33 R34 model skyline except for R34 GTT's these seats & rails cost me over $2600, full reclinable, not willing to separate so please don't ask these seats are now discontinued so they are very hard to find in this condition Price for both seats & rails are $2100 O.N.O pm call or sms 0402072466
post-30634-0-59851500-1391657093_thumb.jpg post-30634-0-99155900-1391657104_thumb.jpg post-30634-0-91649000-1391657115_thumb.jpg
post-30634-0-24776800-1391657126_thumb.jpg post-30634-0-61640200-1391657137_thumb.jpg post-30634-0-23787100-1391657149_thumb.jpg
post-30634-0-63160200-1391657167_thumb.jpg post-30634-0-48864100-1391657178_thumb.jpg
Genuine pair of Ikeya Formula front upper camber arms (negative type) bush not pillow-ball, these will direct bolt in to R33 GTR Gts-t's R34 GTR & Gtt's, less than 9000kms old, not willing to separate so please don't ask price is $285 O.N.O pm call or sms 0402072466
post-30634-0-35447500-1391657235_thumb.jpg post-30634-0-34683200-1391657247_thumb.jpg post-30634-0-42908400-1391657255_thumb.jpg
Genuine Nismo Fuel Pressure Regulator, came off an Rb25 R33 with an aftermarket Greddy 11mm rail, will fit a bucket load of different Nissan models about 15000 kms old very good condition Price is $80 O.N.O pm call or sms 0402072466
Genuine Nissan R33 Gts-t front Tie Rod Brand New, will come with a genuine Nissan crush washer & the wire to hold the rubber boot in place, that's how i bought the kit from Nissan. Price is $60 O.N.O pm call or sms 0402072466
post-30634-0-38892100-1391662373_thumb.jpg post-30634-0-78133700-1391662384_thumb.jpg
  • Like 1
Dam those seats are sexy :3 good luck with sale man ! wish I could afford them hehe
Thanks a lot man appreciate the compliment & well wishes! Hope they go to a good home
Gts-t front Tie Rod will fit gtr33?
Hey mate not to my knowledge it won't, but I'm not too sure......anyone on here knows a definite answer please let us know
Damn GTTs!!! :rant:
Wish they were compatible lol
Lol doesn't make sense what Nissan did! U can always buy some bride rails to suit gtt's & problem solved :P (not that dear of nengun)
Ps awesome car man I followed your build for a while there! I hope to meet you at an event someday & chat about everything skylines!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
