Yeah I thought it would be from there
I didn't end up getting to have a look but I will look tomorrow
Put the gtp's back on today
And took photos of the finished intercooler and black piping :)
And also of the bolts in the guards and stuff
post-108324-14050721317465_thumb.jpgpost-108324-14050721605265_thumb.jpgpost-108324-14050721747491_thumb.jpgpost-108324-14050721857421_thumb.jpgpost-108324-14050721997012_thumb.jpg
  • Replies 293
Attempted to do the intercooler tonight....
F**k you Facebook sales.
The intercooler is for a completely different car
Pretty sure a s chassis.
Anyway I had the headlight on passenger side out..... Then the reo and bumper off and the bonnet latch support and wheel and got the side mount out (found out on the side mount the clamp that is on the pipe that runs to the other side was left loose and the pipe was bearly sitting on.... So mustn't of had much boost running through it.....)
Gave up after finding out it was wrong
Put it all back together and parked it out side. I will test drive tomorrow.
I'm a bit over this wrong parts stuff.
This were the photos I took
Just got to carried away that it wasn't working and forgot to take pics sorry guys :/
  • 10 months later...
Thought I should give you guys an uodate since its been nearly a year
Car is going great. Since last update I have had it through a few transformations
It got a set of hid's in the fogspost-108324-14328056097481_thumb.jpgpost-108324-14328056401847_thumb.jpg
They have since been pulled out and sold to a mate to make room for this, post-108324-14328057023166_thumb.jpgpost-108324-14328057296746_thumb.jpg
I was also defected for rear tyers so I have had rear stockos on for a long time and then finally got new tyers post-108324-14328057826863_thumb.jpgpost-108324-14328058137071_thumb.jpg had all stockos on while getting all new tyers
It now has all the Rays back on :)
Just a narrow band guage had to buy a new 02 sensor for that aswell :P this is untill I get the nistune in an will be aiming for having a AEM fail safe guage, has a wideband and boost in one and can cut the ecu into limp home
I have had it out for a few spirited drives around mountains and a lot of driving around town. Has still not let me down
It also now has a dw300 in tank 340lph e85 compatible pump :)
It also only gets 350km's to a tank :(
This was one of the drives with friends
And I have also been busy with the mrs purple 33 it is now turbo and prettttyyyyyy
And the other day we polished and cleaned both up for a photo shoot
Still awaiting photos but here is a sneak peak post-108324-14328063644137_thumb.jpg
And last but not least I bought a r34 turbo tonight
And will be pulling the exhaust manifold off and replacing studs and the gasket as it has a snapped stud and is leaking :( so all in near future this will happen :)
Reply's and comments are welcome :) please give feed back :) I do miss being on the forums :P
Still have the turbos and I turned the second 25 into a coffe table and sold it
Kept the head. Mate now has a 31 and he is going to 25 so I might steal the block and to a rb30dett or sell off all parts and stick to a pu34 highflow
Went and bought another 34 turbo the other day as it was cheap
So not to sure what I'm going to do but it's just tossing up between the options now
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
