Rays Engineering Nismo LM GT 4 Wheels Forged Monoblock
Satin Black
Diameter: 18" inch
Width: 9.5J (All 4)
Offset: +38
PCD: 5x114.3
Condition : Excellent - NO scratches, dents, rashes of any kind.
Regretful sale, just resprayed to Nismo satin black
Reason for sale: Unfortunately the fitment isn't quite right for my car
Comes with all center caps and air valves
Pickup Preferred - Richmond, NSW 2753
Can post via courier at buyers expense
Inspection can be arranged - 0434 578 190
Payment via paypal, direct deposit or cash on pickup
ASKING $3000
Edited by PureXIII
yea they were touching the front suspension housing.
Very disappointed :(
You need my LMGT's in 18 x 9.5 +12 offset to fix the problem. ;)
  • 4 weeks later...
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
