rb 26 Hi Octane alloy sump kit - $800 $700
D2 front brakes 356mm 8pot, with lines etc for 32 gtr still in box - $1800 $1700
D2 rear brakes 330mm 4pot, with lines etc for 32 gtr still in box - $180
Do Luck rear cross bar suit 32 skyline http://www.rhdjapan....bar-nissan.html- $300
BC BR series coilover 8kg front 6kg rear - $1100 $1000
Greddy polished plenum with 90mm throttle - $1100 $1000
Located in Brisbane 0421883199 txt for more photos
  • 1 month later...
Update of 'for sale list' need this stuff gone, have lowered the prices, will be putting on EBAY soon if I cant sell
Brand new D2 8 pot, 356mm front brakes suit skyline $1600
Brand new D2 4 pot, 330mm rear brakes suit skyine $1600
Brand new Do-Luck cross bar suit 32 skyline may fit other models http://www.rhdjapan....bar-nissan.html $250
Brand new RB26 Hi Octane sump extension $700
Used good condition Polished rb26 Greddy plenum with Nissan 90mm throttle $1000
No dreamers good quality parts here for good price, located brisbane 0421883199
  • 3 weeks later...
  • 4 months later...
